Watts 210 valve
Originally Posted By: agrelling
In the Standards of Practice, section 2.6 Plumbing, I. B. - verify the presence or absence of TPR valves or Watts 210 valves. What is a Watts 210 valve? icon_question.gif
Originally Posted By: rmoore
It’s a temperature sensing gas shut-off valve that, along with a remote pressure only valve, can take the place of a TPR valve.
http://www.wattsreg.com/products/
Then click on "Relief Valves" and then "Automatic Gas Shutoff valve"
(sorry, but I couldn't get the direct link to work)
This one works...
http://www.wattsreg.com/pdf/ES-210-5.pdf
One advantage of this set-up is that the pressure relief valve can be mounted remotely (as long as there is no other valve/shut-off between it and the heater) enabling easier plumbing of the discharge line to an approved or more desirable location.
Richard Moore
Rest Assured Inspection Services
Seattle, WA
www.rainspect.com
