system
(system)
August 10, 2005, 12:00am
system
(system)
August 9, 2005, 12:00am
2
Originally Posted By: kmcmahon This post was automatically imported from our archived forum.
Not a clue.
–Wisconsin Home Inspection, ABC Home Inspection LLC
system
(system)
3
Originally Posted By: rwashington This post was automatically imported from our archived forum.
This is probably a stretch since it appears like it is under the sink but is it an under slab vent for a nearby stove?
– Richard W Washington
www.rwhomeinspections.com
system
(system)
4
Originally Posted By: cbuell This post was automatically imported from our archived forum.
If this was an island sink, I might guess it was an attempt at venting—but in that event it should be above the flood rim of the sink.
system
(system)
5
It is a high loop vent system and it is properly installed per UBC. IRC requires a bit different set up.
– Jeff Pope
JPI Home Inspection Service
“At JPI, we’ll help you look better”
(661) 212-0738
system
(system)
6
you can’t always get these above the flood rim unless there is a short wall at the back of the sink that is a little higher than the sink. However they are supposed to go up “as high as possible”, usually to the underside of the countertop material.
system
(system)
7
Originally Posted By: bsumpter This post was automatically imported from our archived forum.
Thanks all!
As always, NACHI Membership is the BEST!
-- "In the fields of observation, chance favors only the mind that is prepared"
Louis Pasteur
system
(system)
8
Brian,
If you have your Code Checks, look at page 13 of CC Plumbing, special venting systems. They call this a "loop vent."
-- Jeff Pope
(661) 212-0738
system
(system)
9
Originally Posted By: dbowers This post was automatically imported from our archived forum.
Its also called a “Bow Vent” and like Jeff said very common on Kitchen Island Sinks.
system
(system)
10
Thats what I get for lending my books out Monday....
Louis Pasteur
system
(system)
11
Originally Posted By: wcottrell This post was automatically imported from our archived forum.
Actually bow vent is the correct terminology for this vent, still requires special permission from the AHJ for use and sign off on permit. A better solution would have been an air admittance valve. Last time I saw this used is when I was journeyman plumber with my Uncle in 1963.
Regards Bill
system
(system)
12
Originally Posted By: lewens This post was automatically imported from our archived forum.
Most commonly referred to as a cheater vent.
– Just my usual 12.5 cents
From The Great White North Eh?
NACHI-CAN
www.aciss-brant.com
www.certifiedadulttrainingservices.com/
system
(system)
13
Originally Posted By: bkelly2 This post was automatically imported from our archived forum.
Is this it?
http://www.codecheck.com/pg13_14plumbing.html#vents -- "I used to be disgusted, Now I try to Be amused"-Elvis Costello
system
(system)
14
Was this for an island sink? I also don’t see a cleanout.
system
(system)
15
Originally Posted By: Richard A Baxter This post was automatically imported from our archived forum.
The name of this setup has changed alot through the years.Now it is called island venting in the code book under section 913. This looks to be legal under 913.3.
A slip joint p-trap is a legal cleanout for this setup section708--708.7
-- Without plumbers the world would have more crap to deal with.
system
(system)
16
they’re all correct about the vent… and so it’s clear the fifth pic. apeares to be bug spray.
