Originally Posted By: rmoore This post was automatically imported from our archived forum.
Ok…at the risk of showing my ignorance…I’ll bite,
The first photo shows thinwall conduit with a compression fitting.
Aside from a little rust (water getting in somewhere?) it looks OK to me.
Can't see anything wrong with the 2nd photo other than the cheap
knock-off of a Little Giant ladder.
The third (after I'd scrolled right for a couple of minutes) has unmarked
neutrals (no white paint/tape) and an oversize conductor to the single 30
amp breaker (nothing wrong with that) but I can't see anything else wrong.
This all assumes the conduit is the EGC and is continuous of course.
I'm probably missing something but I can't figure out what it is.
Todd...
you have to hit return between images.
Or better yet, when they're this big, leave them as external links.
-- Richard Moore
Rest Assured Inspection Services
Seattle, WA
www.rainspect.com
Originally Posted By: bbadger This post was automatically imported from our archived forum.
Todd this installation sure needs some attention.
The wires do look bigger than 14s but regardless the fact that they are
on a 40 amp breaker may be fine.
Do they feed HVAC equipment?
Todd if you cut and past this into your first post the photos will be stacked insted of side by side. Of course you will have to remove the original BBCode.
Originally Posted By: Greg Fretwell This post was automatically imported from our archived forum.
Look at the inside and outside at the 45 points. Those are 8-32 screws and the whole side comes off. The “standing” part is where the conduit hubs are.
Ahhh…
what I thought was rust in the first photo is the red wires peeking through!
 Gotta get my eyes checked.
Coupled with the photo of the main panel I'm not surprised there was a grounding problem.
-- Richard Moore
Seattle, WA
www.rainspect.com
