Idiotzz. This short video is by an interior basement system company.
:05… They say, “This basement was waterproofed by a company called B Dry…”
He goes on to say they put plastic against bottom blocks and water can’t get out the weep holes (he incompetently thinks THAT is part of the problem)
“All the walls were filling up with water”
Duuuuh, that’s because water was/still is getting into the wall and blocks through EXTERIOR cracks/openings!!!
Then he adds the pipe system, box trench B Dry installed had no fabric around it and little stone and he says it’s garbage and B Dry wouldn’t come back and fix it. looolllllllllll
He then says they will rip out the entire system and install THEIR Bulshttt inside system, LOLOLLLLLLLOLL
This happens all the time. One inside system goes and installs their shttt, the homeowners continues to leak and-or get more mold or efflorescence or have 1+ cracks widening and the first company doesn’t come back or fix the actual problems(outside) and so the homeowner calls ANOTHER bubblehead inside system company who installs their shtt
That fkkkkg basement leaks, has mold etc because… there ARE exterior cracks/other exterior openings that allow water to get into the blocks/wall!!! You idiotssssssssssssssssssssssssssssssssssssssss.
The homeowner has been PENETRATED twice!
All these terds tell people/advertise how good they are, how trusting they are, how experienced they are and a bunch of other shttt
SAME thing here, interior basement system previously installed and…IN goes ANOTHER!@##@! loollll
1:40… http://www.youtube.com/watch?v=CSrdJjlQopA
“The wall is moving… (has efflorescence etc), the water isn’t getting into whatever kind of system they put in”
LOOolllllllllllllllllllllooooooooooooooooooLLLLLLLLLLLLLLLLLLLLLLLLLLLLL
And some think i am or sound, arrogant, llllllllllllllllllllllllllllllllllllllooooooooooooooooooooooooooooool
Hey, another fk up interior bubblehead. Lateral pressure/weight/soil/water etc is on… the OUTSIDE of the wall!!!
Installing ANY kind of interior system will NOT remove, reduce,relieve that weight, pressure etc OFF the outside of the fkkkkkg wall man!!! Dammmmmmmmmmmm
At 8:40 of this stinky azz incompetent video, listen to what the dumb mfr says…
“What we’re doing is a pressure relief system, get the water in, no pressure” hahahhahahahahhaaaaaa
That’s one of the dumbest most incompetent false claims ever!!!
Go back people, go back and read the Donan engineering link, the Dwight yoder builders link, the Fairfax couny VA link, the J McEwen link etc…and for God sake, THINK!! looooolllllllllllllll
Think of what THEY all tell you to do, tell you what needs to be done VERSUS what the incompetent inside system BUTT-CRACKS say!
An interior system and 3 sump pumps were installed here, wall has since bowed in… duh, whyyyyy?
short video http://www.youtube.com/watch?v=j4Vm3vdbF-Y
