You could explain why a life expectancy should be changed or you can suggest we add a new material, system or component (we can research it’s life expectancy if you make the suggestion) or you can suggest a tidbit of information that we can add to the little intro paragraph above each section or you can suggest a new section.
Everyone who helps wins. Prizes will be shipped to the address you have in your member profile.
most decks 15 yr max, if you can find one installed correctly
nachi may want to address 25yr in print
DECKS YEARS
Deck Planks 25
Composite 8 to 25
Structural Wood 10 to 30
Acoustical Tile Ceiling over 25 years old probably contains Asbestos.
Shower heads - 5 years + depending on water quality and mineral deposits.
Toilet tank components - 5 years + depending on water quality and mineral deposits.
GFCI outlets - 30 to 40 years.
Carbon Monoxide detectors - 5 to 6 years.
Just briefly looked and heat pumps are noted as having a longer life then an AC condensor. This would also depend on the area.
Heat pumps 16 years and AC 8 to 15 is listed on chart. Air conditioners are listed 2X and have differant years noted.
Disagree with the paint/caulk/adhesive section, as there are so many types. This should be annual yearly inspection. Suggest a section for yearly maintenance.
Disagree with wood chips/mulch - seems like every year for mulch.
Water Heater is listed 2X one is 10 years one is 20 years. I would have 8-12 years as the expected life of a gas water heater.
I would like to see a condensed version with only furnace, A/C, water heater, most common roof claddings, major kitchen appliances, windows, doors, plumbing fixtures. Basically anything under ~20 year lfe span with a blanket statement about maintenance affecting the longevity.
I would like to see the difference between stainless vs. galvanized for deck hangers etc. in salt air environments. I see a lot of galvanized stuff go to hell in a short amount of time. Also, manufactured home components in any climate.
Change Termite Proofing - 12 yrs. In FL, no such thing as Termite Proof. Termite Bonds are only good for one year and require scheduled treatment.
Water heater - 20+. Really depends on quality and physical/chemical properties of the water. I recommend planned replacement on any over 10 yrs.
Ducting - 10 yrs. An all metal duct should last 100+.
Central A/C - 12-15 yrs. I recommend planned replacement over 10 yrs.
Wireless home network - 50+ yrs. The interstitial airspace should last until the end of the home or the end of days. The wireless router is probably only good for 2 yrs.
