Would like to identify what this is
2017 Build home, in the front yard was 2 pvc access pipes with no caps that were located within a few feet of the fire hydrant. I am just curious as to what they are ?
Could you see if the end was threaded?
I see one pipe in the photo, where was the second one?
Could be some sort of curb stop or pressure regulator. Hard to believe any water service for the home would be so close to a hydrant, which btw would piss off fire fighters being buried like that.
No, this was about 2 1/2 to 3 ft below grade and could not reach it.
In the first picture, located just about 2 Ft to the left of the one you can see. At first i did not see the second one, It was later when discussing with buyer that i saw the second one.
It’s not the water service, meter was located further up in the yard
It could be a B box or a corporation cock.
Please explain what that is Martin
Watch your mouth son
I found this
The b-box, also known as Buffalo Box because it originated in Buffalo, New York, is used by the the Water & Sewer Division to shut off water to structures that that are having repairs made to the internal plumbing system and can not have water running in the line. The box also used to turn off the water for nonpayment.
And this
Definition of corporation cock
: a water or gas cock by means of which utility-company employees connect or disconnect service lines to a consumer
A: F593C THE stainless bolt.
B: Likely a Cleanout, Shutoff Cap or Back Water valve. Your guess is as good as mine.
C: The vertical pipe is call a PVC Riser.
Brian’s got a good definition. It’s basically an underground valve requiring a key that’s usually mounted to a metal rod. The valve should be located below the frost line. It’s a main water shut off from the domestic main water supply.
Heres a b box key.
Around here they are know as “curb stops”. And use the same specialty tool to operate. I’ve installed many corporation valves but we usually put them at the saddle tap right off the main out in the city street, then put the curb stop in just behind the curb line or sidewalk. Hence the name. Had one in the middle of a driveway today. The lid was all bent up and stuck so I couldn’t get a pic of the valve itself.
I was going to say this.
