I’m looking to get either the Zircon MT 6 or the MT 7 for wind mitigation inspections. Has anyone used the newer model? Besides the back lit, and the extension attachment, I don’t see much different in functions. Just wondering if anyone has used both or the newer models and had feedback.
I have used this for over a decade.
I use the same one Mark does.
Or…just mark random lines on the wood with a marker…
<--------Extreme sarcasm not to be taken as true.
I use the m40. This tool is being retired for the MT-7. MT-7 has much greater accuracy and will reduce inspection time.
A simple Google search will explain the difference. Top page link. “The main differences between the MT6 and the MT7 are the MT7 has a backlit screen making it easier to read in low light conditions . It also has 2 depth settings, Normal Scan which will find metal up to 3” deep and Deep Scan which will find metal up to 6" deep." Simple put, Accuracy, Greater depth. Display readability. The way I read it, a no brainer… The MT-7 is an updated MT-6. The MT-7 had hardware and software revocations and component updating.
As explained in my previous post, the M-40 I own is being retired. I am about to purchase the Zircon MT 7. I will donate my M40 to anyone willing to email me and pay for the shipping. If you live in or on the Island of Montreal, PM-Private Message me. I will deliver it to you myself and wish you all the best with your endeavors.
Good luck with your endeavors, Donald. Welcome to the InterNACHI community. Looking forward to reading your posts.
How has it worked for you, Robert? I’ve been using the M40 all along with good results, but I really struggle when there is a metal roof. Does the MT7 do better with those? I have a wind mit to do tomorrow with a metal roof.
Has anyone replaced their MT6 with an MT7 and can tell me if their is any real-world difference in performance?
Thanks
Evening, Peter. Hope to find you well.
The post is 4 years old. I have not used my equipment for 2 years now seeing I retired. As well, I never performed wind mits.
Wish I had more to offer you but I can’t help you at the momenet.
Hopefully someone will chime in. Marc G is experanced.
Good luck with your wind mit.
I’ve used and prefer the M40.
Zircon MetalliScanner M40
On metal roofs I use the pin point feature instead of the wide scan.
Always been OK for me.
I’ve got an MT6 and the M40. You can’t beat the size/convenience of the M40.
Here’s a newer amazon link:
Thank you, gentlemen, for responding.
Robert, congratulations on your retirement!
Marc, I appreciate your input as an experienced inspector. My problem has been that while using the pinpoint feature (blue tube perpendicular to the face of the rafter), the wide scan feature is sensing the roof panel. I’ve learned to tilt the unit so the blue tube is no longer parallel to the roof deck, but pointing up at an angle into the rafter in the area where the nails should be. This seems to help because it gets the detection tube a little farther from the roof. Still, if I waver upward while scanning along the rafter, I will get a false positive. I’m considering trying a small strip of wood or other non-metallic straightedge to overcome that issue. Calibrating out the interference from the metal panels reduces the sensitivity, but scanning both sides of the rafter helps locate the nails that are closer to one side and don’t get detected from the other.
Dave, I’m glad for that evaluation from someone who has used both!
I’ll keep using my handy m40. You (y’all) have probably saved me the disappointment of spending $180 only to find negligible benefit.
It occurs to me just now that the large plastic head of the MT6 would naturally help keep the sensor at a constant distance from the deck. Perhaps this is why in other threads some have reported it better - “more focused” - when dealing with metal roofs. ![]()
Thanks again to all who took the time to send a message!
