Apparently there is or was an HOA (no one knew at the inspection) that required a passive solar system be installed on all homes in this neighborhood.
Not sure if it is still currently required.
I’m trying to figure out how to report on this. The fiberglass panels are old and cracking and there is some evidence that water has been getting past onto the wood framing inside.
I was thinking of reporting that…and then just referring the whole thing to a passive solar expert for evaluation ?
Exactly what I would do. The report the other components independently, connecting them where needed (such as panels causing damage to other building systems)
