2-pole breaker double tapped
Originally Posted By: darmstrong
Found a 100 amp Murray breaker panel with a 2 - pole 40 amp breaker that had two 10 gauge conductors on each pole (double tapped). the breaker was serving the range.
Am I correct in citing this as deficient?
Danny
Originally Posted By: Steven Brewster
Absolutely. Not only do you have a double tap but overfusing 30 amp wire on 40 amp breaker if the wiring is NM solid conductor type. Are you sure that this circuit only serves the stove?
Is there any room in the panel to add an additional 2pole breaker?
There is no feasable way to determine what else is on the circiut without major troubleshooting. I knew this was wrong but wanted some reinforcement.
I'll try and post a photo.
![](upload://oHdt4dwdCrE3Sdp59tSC0wt2cuT.jpeg)
In the photo the breaker is on the lower right side.
Danny
Double taps Recommend immediate further evaluation by qualified person.
That is how I ( A retired Sparky ) would write this up and move on to the next part of my inspection.
No need to look what it feeds it is wrong and must be fixed.
Roy Cooke Sr.
http://Royshomeinspection.com
I agree!
Originally Posted By: jpope
There's that "F" word again. . .
You contradict yourself here Roy but this it more in line with what should be recommended.
It unfortunate, but many electricians don't see double taps as a problem. The sad fact is that if we recommend further evaluation, it may not get repaired. The sparky may just say "It's no big deal."
No offence Roy, I've always valued your opinion. I simply feel that the "Further Evaluation" phrase is over-used by inspectors.
After all, "Further Evaluation" is what we are hired for in the beginning. . .
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Jeff, I agree with you also, but in this case the range top and oven were built ins and I would not try to trace the wires from the panel area to the loads.
After saying that, it just occured to me what they have probably done here. They have most likely used one conductor for each unit (range top) and (oven) since they are separate. Still not right!
After all, there is only so much troubleshooting one can do for the inspection fee alone!
If we don't refer some of the items to quallified technicians, we'll be there all day troubleshooting this stuff.
Danny
We should always defer to qualified technicians. That is not the point I am making here.
When you defer a double tap, you should not recommend that it be evaluated, you should recommend that it is repaired or corrected.
If there is a problem, but you don't know what it is, then you recommend further evaluation (I'm beginning to sound like a broken record).
We hashed this out in another thread recently http://www.nachi.org/bbsystem/viewtopic.php?t=15623
Jeff Pope
(661) 212-0738
Sorry I feel it is a concern . I have made what I feel is the proper call if the client does not get it repaired ,whether it is lack of railing incorrect gutters I am a generalist and do not try to know what is the proper way to fix what is needed .
I guess we will have to agree to disagree.
I do not have a code book, do not want to know codes( Too Many ) I do a visual inspection and if I feel it is not correct write it up . Better to make a mistake on telling them to get further evaluation the too miss something . I try to follow the SOP and stay out of COURT.
Roy Cooke Sr.
Nor do I, however, I am willing to make the statement that it should be fixed rather than evaluated (unless, of course, I don't know what the problem is).
As do I.
Jeff Pope
(661) 212-0738
As do I.
Ah yes but what if I am wrong and it does not need to be fixed.
Example Sq D you are allowed double taps.
Example I feel the furnace could have a crack Further evaluation covers me if it did not have or did have a crack .
CRA ( cover Roys A$$ )
Example ground wire is required on gas pipes in my area and I do believe this is not the case in all areas .
Different codes for different areas so by telling them they need further evaluation I think it is the correct call .
Roy Cooke Sr.
If you don't know, recommend evaluation.
If you know, recommend repair/correction.
Double taps are never allowed on current carrying conductors. Some Square D breakers allow for two conductors - specifically designed to keep the conductors separate and allow for adequate contact - that is not considered a double tap.
Perfect example of when "Further Evaluation" is an appropriate recommendation. Because you don't know if there is a crack although you suspect that there is.
Jeff Pope
(661) 212-0738
If you know, recommend repair/correction.quote]
Evaluation means they should have the whole system checked .
Repair states they should fix what you have said is wrong .
I like the idea of the purchaser getting every thing fixed .
I find an error in the electric panel .
I am satisfied they need to get every thing in the panel fixed .
I do not continue to go down an itemize ever error in the panel there could be considerable
Roy Cooke Sr.
![](upload://edMQeJWayKCKmPtxYaA0cxAqJM2.jpeg)
Jeff Pope
(661) 212-0738
Originally Posted By: cbuell
How about “further evaluation” for this one?
Please read the top we were talking about double poles in a panel .
___________________________________________________________
The above in in My check list would be
Task.............................. Location...........................Time
Repair or replace.............. bed room......................Immediately
This is the same as would come up in my check list for double taps.
Under that would be ( Further evaluation by qualified person.)
You and I both know most people do not do most of those things that should be done .
Roy Cooke Sr.
cbuell wrote:
How about "further evaluation" for this one]
Unless they are hard wired in I do not believe extension cords are part of a home inspection .
Are they wrong certainly.
Roy Cooke Sr.
With no further evaluation necessary, double tapped breakers are not allowed. Fix 'em. ![icon_wink.gif](upload://ssT9V5t45yjlgXqiFRXL04eXtqw.gif)
Jeff Pope
(661) 212-0738
Originally Posted By: rwand1
Further evaluation in my opinion is used by me when I realize I am in over my head. If double taps are not permitted why would you recommend further evaluation?
If you are an experienced inspector and have seen a variety of panels, wiring problems, and other faults, why would you need to recommend further evaluation, when you know its wrong just from exprience? In my opinion I would be stating that there are a number of breakers which are overfused and double tapped. This concern should be repaired/replaced by a qualified/licensed electrician.
Or,
Upon inspection of the electrical panel several concerns were noted. Due to the nature/complexity/unfamiliarity of these issues we would recommend Further Evaluation by a qualified/licensed electrician.
I think we do a great deal of disservice to our clients "sometimes" if we quickly revert to the old life safer "further evaluation."
My thoughts.
Cheers,
Raymond Wand
Alton, ON
Raymond Wand
Alton, ON
The value of experience is not in seeing much,
but in seeing wisely. - Sir William Osler 1905
NACHI Member
Registered Home Inspector (OAHI)
http://www.raymondwand.ca
