cduphily
(Chris Duphily, Level II Infrared Thermographer #8355)
Every installation manual I’ve seen states "min. One foot above grade, 3’ window clearance, 4’ below soffits, can not be located on inside corner of home.
This is 120,000 BTU furnace discharging within 2 ft of a window, within 1’ of a fresh air intake, and located at an inside corner of the home.
AHJ finally went out and looked at it - “it’s fine” No other explanation given. :roll:
If you really want to go in depth, take a more distant view that shows it all at once, put your measurements on the picture, and send it to the manufacturer, with a request for is it OK or not.
Pass that to reply to your customer and to the AHJ’s boss.
You oughta get used to including an overview photo so people can really see what’s going on instead of just measurments.
I can’t really get my head around what you’re trying to show without that overview that speaks 1,000 words.
BUT, I do know that writing to the manufacturer’s helps.
A couple of customers have gotten new inside heat pump units from a builders because the unit was used improperly during construction. Just from an e-mail I wrote a manufacturer asking if use during construction voided the warranty. For that one, (and most others) it did. Gunked it up inside with drywall dust.
Of course, you gotta have customers with enough chutzpah to make it stick.
