gromicko
(Nick Gromicko, CMI)
August 21, 2020, 4:40pm
I use a bucket boom truck on my commercial inspections. I was just wondering if anyone else is using them on home inspections.
They make roof and chimney inspections safe and they also have the “WOW” factor with regards to marketing (especially if wrapped).
They are inexpensive (used) and have a GVWR of less than 26,000 pounds so you don’t need a CDL.
jfudge
(JR Scott Fudge)
August 21, 2020, 4:56pm
2
I used them a lot when installing rural internet.
jdepiero
(Joseph DePiero, CMI® OH 2019004114)
August 21, 2020, 11:15pm
3
I have rented them for commercial inspections, though my drone is a great alternative at times.
jwhitney5
(Joshua Whitney)
August 21, 2020, 11:41pm
4
I wish I had that kind of cash flow to consider this a option. I use a extension pole or a drone depending on the situation.
sbridges2
(Scott Bridges)
August 22, 2020, 2:06am
5
Looks like a potential lawsuit by damaging someone’s driveway with the outriggers.
lkage
(Larry Kage, CMI)
August 22, 2020, 2:21am
6
These worked really well:
I used my friend’s 55 foot boom truck to inspect a steeple once. It was the cat’s meow!
sbridges2
(Scott Bridges)
August 22, 2020, 2:30am
7
The base and thickness of a residential driveway does not compare to a commercial parking lot.
lkage
(Larry Kage, CMI)
August 22, 2020, 2:41am
8
True. And my friend has been using those type of pads for years with no problem.
sbridges2
(Scott Bridges)
August 22, 2020, 2:44am
9
I have seen lumber delivery trucks damage driveways with outriggers using those pads.
lkage
(Larry Kage, CMI)
August 22, 2020, 2:48am
10
So have I…inexperienced operation or not the same pad or both. IMHO
sbridges2
(Scott Bridges)
August 22, 2020, 2:57am
12
By the way Larry what do you think of my driveway, It is pretty bad you think.
sbridges2
(Scott Bridges)
August 22, 2020, 3:01am
14
I bought this fixer-upper 6 years ago and have not got to the driveway yet.
jfudge
(JR Scott Fudge)
August 22, 2020, 3:04am
15
Lots of fun! Renovations never stops!
sbridges2
(Scott Bridges)
August 22, 2020, 3:06am
16
You got that right, burnout.
jfudge
(JR Scott Fudge)
August 22, 2020, 3:41am
17
I renovate at work! I renovate at home!
dbowers
(Dan Bowers, CMI, EDI)
August 22, 2020, 5:24am
18
Curious about the truck … Even or 3-6 story bldgs I have roof accesses. Why would you drag a boom truck along
mwilles
(Martin Willes, CMI)
August 22, 2020, 11:06am
19
My GoPro camera on a pole is easier on the wallet after all it’s residential and a visual inspection with binoculars is acceptable. Even in commercial, where I spent most of my life, you will not be able to access most of the building with a bucket truck. I don’t think they are going to let you set the outriggers down on the landscaping or drive over irrigation lines. Roof access is usually the way to go.
