here is one of the actual problems on the exterior and see that ROOT that grew in the crack
you see, these cracks were there BEFORE the shyster interior drainage system was installed by B Dry, did they (and all other INT system co’s) fix, waterproof the actual problems? Hlll NO
here’s a view of B Dry system inside the basement LOL!!
there is mold on and BEHIND their white BS they attached to the lower part of wall, wonderful
the homeowner did call B Dry and had them come out a week before we did the work, she told them she is leaking, asked them why… they said nothing, that they don’t know, they didn’t do a water test on exterior as we did , didn’t see, note, say anything about the exterior cracks n so on LOL!
Note, the side, front and back walls are bowed in so installing ANY interior system does not remove, reduce any lateral soil pressure and tree roots which CAUSE many of these cracks + bowed in walls and the certainly do not stop water from entering into + through the basement walls smh what-------a---------SCAM
