Beam and support
Originally Posted By: smcintire
http://www.nachi.org/bbsystem/usrimages/more/P1010006.JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/more/P10100071.JPG ]
Originally Posted By: jpeck
Steve,
Based on the non-stained areas, I'd guess that there used to be a different support there. Something with two underside supports and something on the side at the joint.
Jerry Peck
South Florida
Girder joints over supports must be tied (IRC 502.9)
Jerry and Kevin, thanks IRC 502.9 gives me what I was looking for.
Thanks as always
Huh?
(2003 IRC) R502.9 Fastening. Floor framing shall be nailed in accordance with Table R602.3(1). Where posts and beam or girder construction is used to support floor framing, positive connections shall be provided to ensure against uplift and lateral displacement.
Jerry Peck
South Florida
Don’t kill the messenger…it’s noted in code check as 502.9
