Duhhh ummm, what ya think is CAUSING the basement walls to bow inward, crack,leak? WHERE is the cause(s)???
LOOK, lolOlOlOooLLL, they are filling in the cracks on the INSIDE!!! lolol
Wall is bowing in…EXTERIOR cracks in the wall man!!!
THAT’S where the water is getting in, through the exterior cracks so…
filling in ANY visible-interior cracks does N O T H I N G!!!
That doesn’t repair,waterproof the exterior cracks!!! ](*,)
And umm duh, none of these BOZO’s are/have relieved,lessened ANY exterior pressure,weight off the walls!!! ](*,)
same incompetent shtt in Ohio, thats O…HIGH…O for these terds.
Same dumb shtt in New York
NONE of them (as usual) have relieved/lessened ANY exterior weight,pressure that most often CAUSES basement wall cracks,leaks and duh walls to bow in!@#$#@!@!@!
Expanding and contracting clay soil and-or, underground tree roots and-or
concrete slabs and-or porch footing etc cause many of the dang cracks,leaks in basement walls and cause the wall to bow in and these butt-brains either don’t care,don’t give a shtt about THAT (the cause) or don’t KNOW…incompetent!! And again, the exterior cracks are STILL…O P E N!
Some blocks and mortar joints will also…deteriorate!!!
Like this…
http://picasaweb.google.com/101049034584960315932/Crawlspace#5540665133328086770
Same wall is BOWED IN…
http://picasaweb.google.com/101049034584960315932/Crawlspace#5540665069188493442
And sometimes 1 or more inside-blocks will deteriorate
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing36#5451204553850232530
Interior system was installed, some BEAMS too…over $15,000 spent
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing41
Did the companies (2 different interior system companies), did THEY correctly and honestly I–G—dang----DENTIFY the actual problems/causes? NO, thats friggin N…O.
Did either company fix,repair the actual,existing problems? NO, thats friggin N…O.
And, it STILL leaks!!! More mold, more efflorescence, some cracks widening BE----g----dang—CUZ, they incompetently,fraudulently (for self gain) did NOT remove,relieve,lessen the CAUSES of the cracks and leaks and mold etc and instead installed the one stooooooooooooOOOoooopid thing they do!!!
These interior basement system companies have NOT ‘waterproofed’ those basements, BUlll-friggin-shtt man!
They have NOT stopped the water from WHERE it’s FIRST-entering and ummm duh, STILL entering!@#@!@#@!@! How are ya going to stop-prevent mold,efflorescence if you don’t stop the water! What about RADON GAS? Leaving a GAP at,along bottom of wall-floor allows MORE radon gas to enter you foolzz!
And again, they have not removed,relieved,lessened ANY exterior weight,pressure that caused the walls to bow in, crack, leak.
Hey, if and when let’s say…a porch footing has CAUSED aka IS CAUSING a basement wall to bow in, has caused cracks in that bowed wall, which then g dammmit has caused water to enter basement then…YOU need to remove etc the friggin porch footing etc IF you want the problems fixed CORRECTLY!!!
Fc the COST, thing is…have the real problems,causes been HONESTLY and competently diagnosed? And so, if and when a porch footing IS part or all of the problem, the cause of cracks etc then THAT is what needs to be addressed!!! NOT installing a stupid interior system and not filling the cracks you see inside!!!
If the homeowner is given ALL the facts,the causes of why the wall is bowing in etc etc then if THEY decide to hire and install a dumb azz inside system then THAT is on them and LOTS of luck selling that fcd up house/basement…exactly like the one ya see (picas 41)
Yet all i hear and read about is SUPPOSEDLY how honest and how experienced THESE kinds of companies are. This is complete BULLLLshttttttttttttttt! How honest and experienced are THEY when the are doing w t f they’re in the VIDEOS!!! W O W fc g WOW, peeps your getting lied to, misled, misinformed etc by these terds, YES YOU are!!!
Please rise and sing a long to My Old Kentucky Home
…the sun shines bright on my old Kentucky home, tis summer and the basement is leaky and inside system companies r gay…
