‘extensive deterioration and crumbling of at least one course of block…disintegrating block gave way…’ that’s from engineer.
so as has been said, something like this (photo), that INT drainage system co’s do NOT repair
same house, wall is bowed in too with multiple OTHER exterior openings, cracks etc
‘water penetration through block wall… led to crumbling and deterioration of at least one course of blocks, disinttegrating block gave way…’
YET, the interior basement drainage chumps aka liars tell everybody all they need is their drainage system! You know who, like Danny O and the others mentioned here, nah NO worries about allowing water to penetate block walls, just divert it inside the stupid basements, IDIOTS
Just COVER this up on the inside of basements with ‘bright wall paneling’ or a dimpled membrane etc, SCAM, incompetence, negilgence
nah don’t remove the cause of crack, just leave the root and let sht get worse
bowed in block basement wall, bottom course pushed in cracked allowing WATER PENNNNNN_E_TRATION… on-from the outsde sheesh duh
like THIS, long horizontal crack on the OUTSIDE of the stupid foundation wall, umm allows water penetration into blocks and onto basement floor
