Looking for info on this panel. House was built in 1962. This panel is old, but I think it’s not that old. In FL, 99.9% of homeowner’s insurance will require a 4-Point, and a photo of the panel. When they see that panel, they will likely require it be replaced, even though if there’s no problem.
There was no label in the panel, but I think the electric service has been upgraded as there’s no cloth wire, most circuits are grounded. There have been several remodels for the house.
I’m just trying to gain an educated guess to the age of the panel
The cables on the older circuits appear to have cloth jackets (what some call rag wire) which is perfectly fine because they have thermoplastic coating (same standard as today) on the individual conductors. Some newer cables were apparently added later with modern plastic jackets. Both the rag wire and fuse block main disconnect scream original 1962 to me.
That label is saying that the panel is (also) rated to be a 240v only panel (as opposed to the 120-240v main rating for the panel). And if used as a 240v panel, only 240v breakers are allowed.
