Is there a better form or method to create reports in than to use the InterNACHI checklist I have been so clumsily using during each one of the courses?
I have seen the format that Ben Gromicko uses, which I believe is from HomeGauge. Is this the industry standard?
Also is it acceptable for the course if I just type the report into the thread?
Thanks in advance for your responses. Almost done with the courses!
Frank, I’m going to stop inspecting right now and work non stop on substantiating whatever you want me to substantiate.
I wanna deal in facts!
Just like you! :roll:
I like Home inspector pro, but that’s just me. After sifting through all the “witty banter” :roll: I landed on three that interested me. The good software programs usually offer a free trial, and so I downloaded a few and played around a bit until I felt like I found one that worked for me.
I will not tell you which to use, I only offer some perspective, but you should for sure try a few out to see what they have to offer.
Bob, Where do you get the 90% from?:roll::roll: I highly doubt that that is even remotely accurate. I’m not saying that HIP is not the most used. But I doubt your statement is correct.
Don,
If you are early in the process of starting your own outfit, then I suggest joining someone else’s team for a while. Get feet wet, then make the jump when you understand the business.
I know this is not what you asked, but I think that is what you need.
Why?
You need to need to understand how to inspect a house. Most training programs do not teach that.
You need to see how a good firm works. If you don’t, then you may end up burning bridges before you even get started.
You need to know how to market your company. Marketing is an art that some of us do better than others.
PS - Get rid of the snoopy avatar, because you don’t want to get sued for copyright infringement.
Don, Download Home Inspector Pro (HIP), HomeGauge and any others you’re interested in and take them for a test spin. Call tech support and get training if you’d like as well. Taking the programs for a test spin will help you feel comfortable with your decision.
