At the inspection I did today the shower stall had drywall in a place that would get really wet. I’m thinking this would be a defect because pretty quickly the wall would become defined because of so much moisture, but wanted to see if possibly I was missing something. Thank!
Write it up. Move on.
IMO it should be called out as an improper installation.
I would mention it. Area should be tiled or otherwise protected. No shower door either. Still under construction?
Cheers
Unusual having the entire shower wall/stall surfaces without tiles but cement, green and purple board are typically used with a percentage of the shower stall tiled.
I would mention it in my report as untilled shower stall.
Nope, marketed as newly renovated! Haha the renovations were definitely not done by a professional.
That’s what I was thinking as well, it just seemed such an obvious thing for the “contractor” to miss I thought for I second I was missing something. Haha
More caulk means better protection right? ![]()
You stand between a rock and a hard place being able to see/observe and measure the materials used. The lack of tiles or other water repellant materials is obvious, like waterproof wall panels. Walls above the required height of the tub/shower or shower enclosure are only required to be of water-resistant gypsum board
Request disclosure from the vender as to the materials used in the show stall is the only thing I can think of. Permits as well if this is a reno job.
It could be green board.
So, where exactly is it stated that a Tub must have non-absorbant walls? Be specific!
There is a requirement for Showers, but this is not a shower, it is a tub with a shower fixture. Not the same thing.
Homes go back to the beginning of time with indoor plumbing and no special wall requirements in bathrooms.
IMO, Tile, Surrounds, etc. are simply a personal design taste, and not a requirement.
Greenboard drywall is a type of drywall used for walls in damp but not wet zones
Not necessarily accurate…
Is there more to that article that I didn’t see, the thumbnail says it’s not suitable for shower tile installation and very wet areas.
I doubt homes at the “beginning of time” had any plumbing. How could you possibly know this?
You may want to go back and read it again.
Also note, that accorcing to the 21 IRC, the use of “non-absorbant” wall materials in ‘Showers’, (NO requirement in Tubs), is only “required” up to 72 inches (Local for 21 UPC), so the use of it on ceilings is a moot issue.
Very accurate to the op’s picture if that is what was used.
water-resistant drywall can be used in wet locations such as behind tile in bathtubs or shower stalls.2
“ASTM C1396 / C1396M - 17.” ASTM International - Standards Worldwide. 2022
According to ASTM C473,
1.1.4 Water-resistant gypsum backing board, designed primarily to be used as a base for the application of ceramic or plastic tile on walls or ceilings. This product is also suitable for decoration.
