You come across a roof, asphalt shingles, dimensional, drip edge laps the underlayment on the eave drip edge (also the rake), no apparent damage but its all cladded in alumunum.
To elaborate, at the eave, the underlayment is tucked beneath the drip edge, rather than lapping the drip edge flashing.
What would you recommend? Correction, monitoring, or simply state its wrong. I’m leaning towards statement of fact, potential concerns, no evident damage.
The fascia is aluminum wrapped, with drip edge flashing*. The drip edge flashing however overlaps the underlayment beneach the shingles on the eave edge.
Be careful with no evident damage. You had significant limitations such as you did not check the entire roof perimeter and the decking/fascia were covered up or not visible.
I say things like this; I lifted the shingles in a couple of select locations. There was no visible drip edge flashing which is recommended. Drip edge flashing protects the roof edge and fascia from moisture damage. Additionally, the fascia aluminum wrap overlapped the shingle underlayment which is improper or substandard and may promote damage. Recommend blah blah
You’re right of course…drip edge goes under the roof felt on the bottom edge…you should call it out but I doubt they will fix it. It’s done this way because the framer felts the roof but the roofer applies the drip edge. By the time the roofer gets there the felt is already nailed in place and the drip is hard to fit under the felt with nails in the way. So he just nails it on top.
They could pay the framer to put the drip edge on but builders won’t do that because then they’d have to take money from the roofer to balance out their budget…and the roofer will balk at this…
That’s a real pretty picture…see 2012 IRC R902.8.5… where it says “underlayment shall be installed over the top of the drip edge…”… .in 2018 they removed the requirement for drip edge and changed it to “where required by the manufacturer”…
Nobody was doing it on new construction…home inspectors had to call it out…so the builders petitioned to have it changed…well…that’s my educated guess…
