I inspected a home with what appeared to be James Hardie fiber cement siding. There were many cracks observed in the siding. I think this was caused from settling. There were no indications of cracks in the poured concrete foundation walls, drywall or stone veneer. No collateral damage. Only cracks in the fiber cement siding. The home was built in 2005. Any recommendations?
Yes, it was fastened improperly according to recommendations, as evidenced by the exposed nails in the pictures. The cracks in the gaps appear to be even, opposed to being wider at the bottom most likely if the cracks were caused by settling. This is just my opinion.
http://www.jameshardie.com/pdf/install/hardieplank-hz5.pdf
Exactly, improperly installed. Only need nails at top edge (should not be visible), except in high wind areas. This allows for movement, which can help to avoid cracking.
I see they have face nailed it which is normally only done in high wind zones. If they did blind nailing and also face nailing, it was installed improperly and is most likely the cause of the cracking. The 2001 installation guide would have been in effect for a 2005 home.
In your zone (HZ5), when face nailing to OSB (most likely nowadays), fasteners must be no more than 12" OC. Those are more than a foot apart. Was there OSB visible on the interior garage wall? At that time, gaps between boards could have been in moderate contact or up to 1/8" gap AND CAULKED. None of those are caulked. Typical builder didn’t read or follow the manufacturer’s instructions and the warranty is most likely void due to the improper installation.
Installation guide can be found at: 2001 Hardiplank Lap Siding Installation Instructions
I would agree improper installation.
Most of the photo’s of cracks are in line with the placement of nails.
There was O.S.B visible on the garage interior wall. I will recommend that it be further evaluated by a qualified James Hardie siding contractor. Thanks for the feedback.
Yup to all the above, I’ve installed this product successfully and never had a problem like that! Whomever did this is going to be getting a real wake up call!
appear to be over driven nails
ouch that is one expensive screw up. Hope they got some money back
I noticed most of not all of the cracking was at or a long the fasteners, the installation of the nails is subpar (some are protruding and some are not). Either the fastener length is too short, or the substrate underneath has become rotten. The latter seems likely because of the lack of caulking at joints and vertical side(s) of window openings. Water intrusion also could have caused the nails to corrode, and some non-professional installation of new nails was done incorrectly. It looks like the material has a fresh layer of paint as well. Somebody thought they could perform a little maintenance and didn’t know what they were doing.
Thanks for sharing
Don’t bounce the ball on the side of the house! Especially when your father is sleeping!
Is that a Titleist? They have a distinctive sound.
While most nails seem driven properly “Snug”, there are also many that seem under-driven, or over-driven. I Noticed some cracks are right at the nail heads as well, and yes, I agree i see a very subtle change in crack dimensions top to bottom in the sample viewing I did from your pics. I’d contact Hardie and ask how they recommend repairing sections. They may have kits.
Only recommendation I would give is just the factual observation of improper installation, referring to manufacturers installing instructions. You shouldn’t se any nails. Also only replacing the damaged ones will not fix the problem. Great insight from everyone!
Why is that?
Exposed nails could allow for moisture and water penetration also could decrease the integrity of the surface.
I’m not saying you are wrong but Face nailing is an approved method for James Hardie.
Thank you for sharing your knowledge.
