Help with an Electrical Panel
Originally Posted By: mgault
http://www.nachi.org/bbsystem/usrimages/0/050818053312.JPG ]
Second shows 'bunched' nuetrals and grounds into the bar. ![icon_eek.gif](upload://yuxgmvDDEGIQPAyP9sRnK0D0CCY.gif)
[ Image: http://www.nachi.org/bbsystem/usrimages/0/050818053304.JPG ]
Tried to get a third in (is there a limit?)
Ah here it is.
Nicely detailed "note book" paper to id the Breaker assignments..
[ Image: http://www.nachi.org/bbsystem/usrimages/0/0508180529361.JPG ]
Appreciate any help!
-Mike
A to Z Home Inspections, LLC
www.atozhomeinspections.net
Originally Posted By: Joey D’Adamo
Those pigtails are likely okay.
Originally Posted By: jpope
No problem with the wire nuts.
Neutrals are current carrying conductors. Current carrying conductors require individual terminations (as of 2002).
Grounds and neutrals were never allowed to share the same terminal connection as far as I know.
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
The wire nuts appeared to “extend” several neutrals from the bottom of the panel up to the areas where they were ‘bunched’ into the common bar.
Is that okay too?
-Mike
Originally Posted By: lkage
mgault wrote:
The wire nuts appeared to "extend" several neutrals from the bottom of the panel up to the areas where they were 'bunched' into the common bar.
Is that okay too?
Grounded conductors (neutrals) need their own termination. One per lug screw.
"I have never met a man so ignorant that I couldn't learn something from him."
Galileo Galilei
Originally Posted By: lgoodman
They have already answered your first two questions. Wire nut on neutral o.k. If the wire is too short to reach I know of no other practical solution.
One neutral per screw. Grounds may be ganged.
Notebook paper directory. Give the man extra credit. Many electricians won't even use the factory provided sticker or they provide minimal, confusing and incomplete information. Can't be too much info for me. I carry a Sharpie and write on junction box covers and leave all kinds of notes for whoever may come along after me. You could advise the client to have the electrician who makes repairs also make the directory more permanent.
of that?
-Mike
I believe it's:
(2) 14 or 12 CU per lug screw
or
(2) 12 or 10 AL per lug screw
Galileo Galilei
I wrote it all up…
In for a penny, in for a pound (mixed metaphor or British origin? ![icon_biggrin.gif](upload://iKNGSw3qcRIEmXySa8gItY6Gczg.gif) )
-Mike
I agree with Leigh. A notebook paper directory that is right is a lot better than the factory sheet that is wrong.
