3:35 mark…
Why didn’t he IDENTIFY how/where water is getting in?
Why not do a WATER TEST with a hose and see if water is entering through 1 or more cracks, seams, rods holes, basement window(s)??? ](*,) (duh tar on wall,you’d still see the water enter if there’s a crack, seam, rod hole,window problem)
There’s plenty of room to hand dig if needed and its not that deep to footing,sheesh!
Water might be entering just under/around a basement window…an easy fix.
Point is, take a little TIME and identify,locate where the water is first entering, NOT bypass that and just say…let’s install a dork-brain interior system and allow water to continue to enter and run down/through the dumb az wall and hope it all goes behind that stooooopid memebrane!@!@! Incompetent!
And of course, how about the other dork applying tar on inside walls, lol!!
