Although the thread is over 5 years old, You should be welcomed.
Welcome to our forum, Michael!..Enjoy! ![]()
Go into the camera settings on your device and set the following: Photo resolution should be around 1 megapixel, or around 1280x720. The resolution must be higher than 640x480 to work with HomeGauge. … When you go to take a photo in HG Companion you will be prompted to select the camera you want to use.
