Brian, yes sir that is a part of her problem as are some small cracks etc above grade in a few mortar joints but main problem is at least 1 exterior corner crack in block wall. If she doesn’t get the corner waterproofed on exterior then she will still leak, a lil less but i mean lolll. We waterproofed her front corner 20 ish yrs ago, an exterior corner crack was problem, since we did that front corner not a drop of water in that corner
she has something like this on exterior wall below grade (corner)
so again, the inability of some home inspectors who don’t want to, care to understand these actual problem (s) and solution screws over buyers $$, or maybe some think they know waterproofing/leaky basements better than we do
how in the world would putting in a long, new downspout extension keep all rain, snow away from, off–of, the depth of any basement wall? That’s impossible and of course long downspout ext or raising the grade doesn’t seal/waterproof these cracks and so, all the time over 4 decades i see this shtt lolol
i see many do the same thing with concrete, they’ll pour concrete on top of existing concrete (of leaky basement, like a driveway side) or they pour new slab (s) if existing slab settled or has cracks in slabs and so on, still leak, they did not identify ALL the actual problems and did not correctly fix the actual existing problems and lolol did NOT disclose the existing problems aka excisting defects the house has prior to sale of the dang house.
Some here get me wrong as they blindly think i’m just here bashing HI’s, nonsense!
Many HI’s are great and imo buyers should get a home inspection, said that many times.
These homeowners tried several water diverting techniques lol, they kept leaking and efflorescence and some mold on inside block wall at-near corner, got worse, why? Because there were exterior corner crack in block wall, needed exterior waterproofing of this corner
So imo, ‘some’ HI’s should simply stop recommending these bullshtt, moronic, supposed solutions for these leaky basements sheesh lolol, you did NOT correctly IDENTIFY the actual-existing problems baby.
