ROOF
INSPECT:
I inspected the roof-covering materials:
__X___from the ground level
_____ from the eaves
_____ from a ladder
_____ from the roof surface
_____ from a window
_____ using binoculars
_____ using a camera extension pole
The roof-covering materials were not inspected, because they were:
_____ inaccessible
_____ unsafe
_____ not present
_____ not within the scope of the inspection
_____ I inspected the gutters:
_X from the ground level
_____ from a ladder
_____ The gutters were not inspected, because they were:
_____ inaccessible
_____ unsafe
_____ not present
_X I inspected from ground level or the eaves the downspouts.
_____ The downspouts were not inspected, because they were:
_____ inaccessible
_____ unsafe
_____ not present
_____ I inspected the vents, flashing, skylights, chimney, and other roof penetrations:
X_ from the ground level
_____ from a ladder
_____ from a window
_____ The vents, flashing, skylights, chimney, and other roof penetrations were not inspected, because they were:
_____ inaccessible
_____ unsafe
_____ not present
_____ I inspected from ground level or the eaves the general structure of the roof:
_____ from readily accessible areas
_____ from readily accessible panels
_____ from readily accessible doors
_____ from readily accessible stairs
_____ The general structure of the roof from the readily accessible panels, doors or stairs was not inspected, because it was:
_X inaccessible
_____ unsafe
_____ not present
DESCRIBE:
The type of roof-covering materials I observed can be described as:
X_ asphalt shingle
_____ wood shingle or shake
_____ concrete or clay tile
_____ metal
