belliott
(Bob Elliott, 450.0002662)
July 15, 2009, 9:18pm
Just curious what the Brethren see.
This Deck seems dangerous and wonder if
would like to see how many defects they spot from pics.?
mroberson
(Michael Roberson)
July 15, 2009, 9:30pm
2
Pic 1, Nailed not lagged to the house
Pic 2, post is lifting or not in the ground right,
Pic 3 not sure
Pic 4 Cant recognise
Pic 5 Railing configuration, nailed on? Not fond of that type of setup, only works with screws, and the occasional 2x4
belliott
July 15, 2009, 9:34pm
3
mroberson:
Pic 3 not sure
Pic 4 Cant recognize
Check joist /beam connection I will add a different angle
Any comments on stairs?
Check posts (whole thing lifted easily)
mcyr
(Marcel Cyr, CMI)
July 15, 2009, 10:12pm
4
Nice deck Bob;)
List of what I see.
Toe nailing missing @ joist hangers
Split joist
Knot hole at top of joist may exceed allowable limits
Ledger nailed with air gun instead of lags or bolts
No visible sign of ledger flashing
Framing lumber is of #2 framing grade in lieu of PT lumber
Post base broken and post unsecured
Risers appear to exceed 7-3/4" in height
Improper post to beam connection
Cantilever exceeds the 1 to 4 rule
Missing hangers at band joist
Beam splice not in center of post
Possible missing center stringer, dependant on width of stairs
No rail post on the railings and hand rails.
Hand rail not grippable.
Missing the 1" nosing overhang on the treads. Nails sticking out of rail and pulled away from wall.
Improper attatchment of stringers to deck connection.
Ok, how many did I miss?:mrgreen:
gromicko
(Nick Gromicko, CMI)
5
I don’t see a single guardrail post, just 2"X 4" stair handrail posts. Are there any guardrail posts?
www.nachi.org/deck-inspections.htm
jfunderburk
(Joe Funderburk, CMI)
July 15, 2009, 10:27pm
6
Is it treated wood? Sure doesn’t look like it.
belliott
July 15, 2009, 10:30pm
7
Hahaha
Good catch as all they did was shoot a couple screws through the end balusters.(started cracking when I applied horizontal pressure)
Never would have made 200 pounds pull.
I told my client not to have any deck parties just yet.
belliott
July 15, 2009, 10:34pm
8
mcyr:
Nice deck Bob;)
List of what I see.
Split joist
Wow can I paste into my report?
Good job Marcel!:mrgreen::mrgreen::mrgreen:
I missed a couple.
What do you mean by cantilever as this is free standing (especially with those nails at the ledger) hahaa ? (double ledger) (loks like they kept the old one which was bolted behind it)
mcyr
(Marcel Cyr, CMI)
July 15, 2009, 10:43pm
9
relliott:
I missed a couple.
Well, the third picture seemed to indicate the framing cantilevered over the last beam support, could not see as a whole. Might be wrong then on that one.
belliott
July 15, 2009, 10:54pm
10
I do not believe it was Joe.
Lost that one in all the other issues.
belliott
July 15, 2009, 10:58pm
11
Need to run on an after rush hour inspection but here is a over view.
Hope this Developer does not toss me out like the last one this morning.
Will tell that story later (met him last year)
jjonas
(Jeffrey Jonas)
July 16, 2009, 1:50am
12
Bob,
I assume you mentioned the placement of the A/C condensing unit…
From one manufacturers tech manual…
https://www.acwholesalers.com/EasyEditor/assets/ssx14_tech.pdf (page 4)
[FONT=Arial][size=2]Special consideration must be given to location of the condensing [/size][/FONT][size=2][FONT=Arial]unit(s) in regard to structures, obstructions, other [/FONT][/size][size=2][FONT=Arial]units, and any/all other factors that may interfere with air circulation. Where possible, the top of the unit should be completely unobstructed; however, if vertical conditions require [size=2][FONT=Arial][size=2][FONT=Arial]placement beneath an obstruction [/FONT][/size][/size]**[FONT=Arial][size=2]there should be a [/size][/FONT]****[size=2][FONT=Arial]minimum of 60 inches between the top of the unit and ****the obstruction(s). **[/FONT][/size][/FONT][/FONT][/size]
[size=2][FONT=Arial][FONT=Arial][size=2][FONT=Arial][size=2]The specified dimensions meet requirements [/size][/size][/FONT][size=2][FONT=Arial]for air circulation only. Consult all appropriate regulatory [/FONT][/size][size=2][FONT=Arial]codes prior to determining final clearances. [/FONT][/size][/FONT][/FONT][/size]
belliott
July 16, 2009, 3:29am
13
I do not really feel there will be impeded air flow at the location however you do make me remember there is a vent opening for a future dryer nearby.
rmaday
(Rick Maday)
July 16, 2009, 3:44am
14
Who let you out of the city?
Was this in Lake County?
belliott
July 16, 2009, 3:50am
15
Cute
CCHills
I was in Dapkus /Merino land
tspargo
(Tim Spargo, CMI)
July 23, 2009, 6:45am
16
blocking… would have been required here to block at intervals, blocking over beams woulda been nice! Joists blocked and blocks nailed to beam or A35’s
we use lateral bracing here as well (knee or other)
bdoles2
(Brian K. Doles)
July 23, 2009, 10:06am
17
Looks like YellaWood to me.
I can’t believe there is not a single rail post on that rail system. Too funny!! Those joists should be either toe nailed or strapped to the beams.
