Well most of these cracks extend further down the foundation wall so sealing the top 2’ whatever of these cracks does not seal any part of these cracks that continue downward, eh lol
so do i have this right, he’s a lil concerned about the top of the crack YET says nothing, does nothing about the rest of it that extends further down lol
apparently built 1927, we do many of these types of older joints, another bowed in block basement wall, has multiple exterior cracks that allow water in basement but as is often the case, some INT drainage system moron will likely get the job and install an INT drainage system and some wall anchors or carbon fiber straps and then cover the wall with cheap paneling to hide/conceal the existing defects, water, cracks etc
well lol do you/others think they should understand it?
see here short video, poured wall crack that extends DOWN to footing, the lady hired some jerk who
1:05 mark slapped some crap on the UPPER 2 ish feet of crack, and they injected crack on the inside, kept leaking, video shows why and vid shows what Marky n crew has seen for decades n that is lol, most of these crack extend DOWN so slapping junk on upper 2 ish feet doesn’t do squat about the rest of the crack
Siiiimon, you ‘get it’, wish other HI’s would because THEY are costing their clients $$$, yep
exterior drain tiles pffftt, yet again had nothing to do with WHY the basement leaked in 2 areas, as most if not all interior basement system companies lie about n try n BS homeowners about… and they do lol quite often, pathetic
This is David Asselin He is a INachi inspector, Burnaby, BC (Canada) NACHI15031819
From his website.
David has over 15 years of construction experience and has led a successful commercial contracting company
David has over 15 years of construction experience, from concrete forming, glazing, framing and insulating. He is the marketing genius behind our phenomenal success. He creates a constant stream of informative videos to help homeowners with maintenance. David is the visionary behind the innovative changes happening to the inspection industry. His endless energy and positive spirit focuses us all on one of the most important aspects of Inspect Canada: client care and delivering the best product possible.
