Ladder Leg Levelers
Hello!
Home inspection student here. I’m getting ready to buy my first ladder. I’ve zeroed in on the 17 foot Little Giant articulating ladder. I’m wondering if it’s worth spending the extra $150 for the model with built-in leg levelers. Does the added utility justify the greater cost and weight? Thank you for your insights!
-Jesse (Minneapolis, MN)
Yes! My Little Giant wanna be is only 13 feet. But for the real ladder (extension) I use this:
Ladder falls kill more Home Inspectors than anything else. Don’t be a statistic!
Good to know! Thank you!
This is the one I use with the leg levelers. Leg levelers are mandatory for me. It wasn’t an extra $150 though. The whole ladder was like $180. I’ve seen them for 160 at Costco.
Costco has the best price with leg levelers
I’ve a Little Giant with the levelers and have used the levelers several times. Mine was on sale at Costco, so it wasn’t an added expense for me. I think it’s still worth it.
Thanks for the tip! Sounds like Costco is in my near future!
Morning, Jesse. Pleasure to meet you. Hope to find you well.
Welcome to the InterNACHI community forum.
My thoughts having used ladders for 50 years.
Little Giant articulating ladder. Great choice.
Typically you will be able to mount your ladder on a fairly flat level surface.
I want to be away from the wall and be able to dismount are remount safely. I used outrigger.
Very inexpensive. Takes seconds to mount.
Transitioning from a roof to a ladder is a high-risk moment for accidents. While falling while on the ladder is the leading cause of injuries, the critical moment of stepping off the roof onto the ladder is a major factor, often due to a shift in weight and improper ladder extension.
I’ve never used that outrigger, but I like it.
Robert, Thank you very much for the mentioning the outriggers. I’d never heard of them but I can see how they could improve safety during the transition from ladder to roof and from roof back to ladder.
I’m confused. Not unusual but… How do you get off the ladder onto the roof? The ladder is farther away from the roof and you have outriggers to the left and right? This looks more dangerous to me.
I’m with you Mike that looks more dangerous. Might be nice for replacing the gutter, but not for climbing on the roof. Of course in typical WAFI fashion it has nothing to do with the OP’s question.
I have used them, and I like them a lot. Mine are spread wider, and the ladder is in contact with the roof edge. They significantly reduce the risk of the ladder sliding left or right while mounting and dismounting the roof.
Evening, Mike, Robert K.
Let me clarify what I used outrigger on. They were installed on extension ladders.
They do not fit on articulating ladders due to the outward flare or rung shape.
As for dismounting the roof. The pattern is the opposite of mounting. I would dismount and mount the second highest rung from the side. It takes getting use to.
Remember, the ladder does not move. It is planted on 2 sides and as soon as weight it added to the outriggers you are stationary.
It takes some getting use to mind you but practice makes perfect.
Leaning ladders against gutters the ladder has a tendency to slide on and crush the gutter.
It was my preference.
Please explain to the new InterNACHI community member Mike Hardy, the OP what “WAFI” refers to Robert.
I have sent in a complaint.
NOTE: COE: 1. The InterNACHI® member shall not engage in any act or practice that could be deemed damaging, seditious or destructive to InterNACHI®, fellow InterNACHI® members, or InterNACHI® employees, leadership, or directors. Accusations of a member acting or deemed in violation of such rules shall trigger a review by the Ethics Committee for possible sanctions and/or expulsion from InterNACHI®.
Here is the OP’s post. Hello!
You post: As for in typical fashion it has nothing to do with the OP’s question, I disagree. I quote, Little Giant articulating ladder. Great choice.
Moreover, Home inspector ladder accidents are a significant safety concern, with roughly 500,000 injuries and 300 fatalities occurring annually, often from falls of 10 feet or less.
The ladder leveler in this case leaves a lot to be desired. And for $150 dollars is nothing more than an expensive addon.
I never paid more than $150 for an articulating ladder under 21 feet. Never.
The first ladders for home inspectors in my opinion should be a step ladders. Three or four foot and six foot step ladders.
The next ladder would be for exterior use. A simple 21’ foot extension ladder with outriggers. The outriggers come in various styles. Brian Cawhern style is more tapered.
A straight claw hammer works great. :blush:
