Moisture meters
Originally Posted By: elewis
Okay guys, what is the recommended handheld moisture meter on the market…and which one will give me the most for my money?
Originally Posted By: lkage
I like the Tramex Moisture Encounter Plus: http://www.tramexltd.com/page/moistplus.html
“I have never met a man so ignorant that I couldn’t learn something from him.”
Galileo Galilei
Originally Posted By: troberts1
I use the protimeter aquant moisture meter, it is intrusive and non intrusive in one meter. icon_smile.gif
Originally Posted By: dvalley
I absolutely concur with Larry.
I use mine on a daily basis.
As for pricing. The HI store has the best price.
![](upload://me4MtRe3nGBGET8vgZY42XGj9kl.gif)
David Valley
MAB Member
http://www.masscertified.com
Originally Posted By: psabados
Ditto the Tramex
Paul
NACHI Vice President
NACHI Foundation, President
Convention Coordinator
Originally Posted By: lwillick
Eric:
I also use the Tramex moisture encounter meter. It’s a good one.
regards
larry
Originally Posted By: gporter
Ditto
Gary Porter
GLP’s Home and Mold Inspections LLC
Orlando, Fl 32828
321-239-0621
www.homeandmoldinspections.com
Originally Posted By: jhugenroth
Dito on the Tramex
The only problem I have with this meter is that the pointer needle needs to repaired. It has become disconnected or worn due to use. I have had mine for many years.
regards
larry
What pointer needle?
As far as I know, the Tramex is a non-destructive meter with no needles.
Am I missing something?
David Valley
MAB Member
Maybe his pad came loose. Before it falls off use a touch of hot melt glue in a corner, if this is the case
Paul
Hi David:
Yup !!
Mine has a pointer needle
Just like the speedometer needles in your automobile
Mfg in Ireland & distributed thru Professional equipment, 130 Dale Street, West Babylon, NY 11704
Ph: 1 800 334 - 9291 (if they r still around - been a long time)
Don't forget I bought mine many years ago
I have been in this business for over 20 years
Regards
larry
Hi Paul:
I don’t know how to open this unit
Had it repaired once years ago
Took over six weeks
Many of the professional restoration companies use this model.
Regards
larry
Hi Paul:
The pads are ok
It’s the needle on the gauge that go 's from greeen to red
Any ideas on how to open this puppy to repair it ?
Regards
larry
My error,
I thoughts were along the lines of pins. Yeah, kind of hard to read when the mph when the dial needle doesn't move. ![icon_redface.gif](upload://f7DX2EWhmUfsDapWaYT3oJHMCj1.gif)
Paul
Hi Paul:
If you have any ideas as how to access the inards to repair this unit
Plse advise
Regards
larry PS There is no business here these days
Larry
Mine has four small phillips head screws on the back. But how you get into the dial movement is a good guess. Good luck if you try to disassemble it yourself.
Paul
Thks Paul:
Got to go & drool over my new camper now - Big Foot 10.6E
Catch you later
Regards
