0k, I’ll pick on the report too :)… first off I like it overall, I have your template and have modified it significantly over time…
you place the realtors entire contact information- is this ad space for your buddies?
why is stain better than paint on decks?
you recommend any cracked, deteriorating concrete or walkways be replaced? what if the driveway is gravel?
the rat feces comments: [FONT=Arial][size=2]
[size=2][FONT=Arial]one or more areas. The Center for Disease
Control (CDC) defines this as less than 20 feces per square foot. Rodent infestation may be a safety hazard
due to the risk of contracting Hantavirus Pulmonary Syndrome (HPS). HPS is a rare (only 20-50 cases per year
in the United states) but deadly (40% mortality rate) disease transmitted by infected rodents through urine,
droppings, or saliva" would freak anyone out. living in areas with a lot of corn fields, mice, rats, ect- try come indoors every winter. its what they do. [/size]
– Yes but what is posted is a fact.
**electrical: [FONT=Arial][size=2][FONT=Arial][size=2]
[size=2][FONT=Arial]Exposed wires should have a either black tape
when did black tape become a safe way to cap an unterminated wire?[/size][/size][/size]
– Your right. Color code nuts are required.
**AC: [FONT=Arial][size=2][FONT=Arial][size=2]
[size=2][FONT=Arial]Foam insulator is cracked or missing. The insulation is used to help prevent the****pipe from sweating. Recommend hiring a qualified HVAC contractor for repair.
you need an HVAC tech to put on a piece of pipe insulation?[/size][/size][/size]
– Depends on who you are
I usually tell the client to have them do it when they are out doing a MX checkup.
**service wires:[FONT=Arial][size=2][FONT=Arial][size=2]
**[size=2][FONT=Arial]The service drop wires are in contact with trees or vegetation. Recommend having****a qualified tree service company or arborist prune or remove trees as necessary to prevent straining or **abrading the service drop wires.
doesnt the electrical company take care of the wires up to the meter? they do here
– My area… City’s responsibility is limited to those trees located within a public right of way. Trees located on private property are the responsibility of the property owner.
**GFCI:[FONT=Arial][size=2][FONT=Arial][size=2]
[size=2][FONT=Arial]One or more electric receptacles at the
**garage had no visible ground fault circuit interrupter (GFCI) protection. **
didnt you test them?
– Of course. Your right visible wasn’t a good word to use.
**flues: [FONT=Arial][size=2][FONT=Arial][size=2]
[size=2][FONT=Arial]Recommend cutting sheeting
from the flue so there is at least a 2 inch clearance from all combustible materials by a licensed contractor.
isnt it 1" for type B flue clearance? – Yes your correct. Was I talking about a chimney pipe or furnace flue?
[/size][/size][/size][/size][/size][/size][/size][/size][/size][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT]**
**tub: [FONT=Arial][size=2][FONT=Arial][size=2]
[size=2][FONT=Arial]Bathtub is missing the water stopper. Without it you cannot fill your tub up with water. Ever seen the rubber stoppers sold at walmart?
– Yep and I’m sure thats where my client headed sometime after closing unless all they do is take showers
was the report with pictures too big to load? – Yes Many people still use slow connections. But with that said I’m getting ready to put up a recent report with pictures.
You call out many items as defects that would be in my regular section as maintenance tips or noted damage- like the stopper. or the flexible drain in bathroom sink but thats your style. – My style to now I’ve changed since putting up this report, your right.
**To me everything is price relevant. If I bought the house and the drain worked fine, I wouldnt replace it. If it clogged a couple times then I would. things cost money. an older house is cheaper than a new one. but you get older pieces and parts - you replace and update as needed. I dont like to provide links to places that are selling items like your insulation links. OF COURSE they want people to upgrade their insulation- its how they make money. **
– Not sure what your referring to here. I can’t see the report right now.
**I hope you arent offended by my criticism.
– Not at all. I’ll let everyon know once I put up my latest. Thank you I appreciate your comments.
[/size][/size][/size][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT]**[/FONT][/size][/FONT]
