**2005 NEC’s Take On It
Location, Damp.
**Locations protected from weather and
not subject to saturation with water or other liquids but
subject to moderate degrees of moisture. Examples of such
locations include partially protected locations under canopies,
marquees, roofed open porches, and like locations,
and interior locations subject to moderate degrees of moisture,
such as some basements, some barns, and some coldstorage
warehouses.
[FONT=Times-Roman][size=2]**[FONT=Times-Bold][size=2]D) Bathtub and Shower Areas.
**No parts of cordconnected
luminaires (.xtures), chain-, cable-, or cordsuspended-
luminaires (.xtures), lighting track, pendants, or
ceiling-suspended (paddle) fans shall be located within a
zone measured 900 mm (3 ft) horizontally and 2.5 m (8 ft)
vertically from the top of the bathtub rim or shower stall
threshold. This zone is all encompassing and includes the
zone directly over the tub or shower stall. Luminaires
lighting .xtures) located in this zone shall be listed for
damp locations, or listed for wet locations where subject to
shower spray.
2002 NEC’s Take On It
**[FONT=Times-Bold][size=2]II. Luminaire (Fixture) Locations
410.4 Luminaires (Fixtures) in Specific locations.
(A) Wet and Damp Locations.
**Luminaires (fixtures) installed
in wet or damp locations shall be installed so that
water cannot enter or accumulate in wiring compartments,
lampholders, or other electrical parts. All luminaires (fixtures)
installed in wet locations shall be marked, “Suitable
for Wet Locations.” All luminaires (fixtures) installed in
damp locations shall be marked, “Suitable for Wet Locations”
or “Suitable for Damp Locations.”
**(B) Corrosive Locations.
in corrosive locations shall be of a type suitable for such
locations.
**[FONT=Times-Bold][size=2]Location, Damp.
warehouses.
“Such As” only refers to examples…
It is MY stance and opinion and it is totally fine if someone does not agree with me…never said I was the HOLY grail of the NEC…lol…debate is welcome.
Now…my opinion in the 2002 or clarrified in the 2005 is that the shower location is a potential location for moisture and damp conditions…I would prefer a vapor trim…and properly wattaged bulb as greg is correct on the bulb and most of the time most IC rated cans are 75W or less…could be higher but again with a NORMAL bulb in it…you should be able to see the wattage rating…this is why I said a normal bulb.
Personally…HI’s are not code inspectors…I would have a problem with a light that is only 7’8" off the floor…and has an open bulb in it…and since it has a shower…and nothing mentioned about an exhaust fan…assuming someone would ask that…we have moisture build up…and again in my opinion in THIS example…I want a vapor trim on it…that makes a normal IC can comply with a damp location classification…based on the trim.
Agreed…a Recess Can can clearly be over that area…JUST wanted HI’s to think a bit…
Again…these opinions expressed my ME…are from ME…not anyone else…
I feel this is why the 2005 has made an attempt to clarrify…kinda the point of my most…having greg point it out is cheating…lol…your supposed to answer last greg…tehehe[/size][/size][/size][/FONT][/FONT][/FONT][/size][/FONT]
