This is a 13 year old home without kickout flashing. Hard to argue with a good photo or two.
Classic picture…
Save this one…
Mark, can I have permission to use this photo in the roof course?
Thanks,
Kenton
Absolutely, feel free.
Thanks Mark!
Hey Mark! Great Pic.
How’s HI treating you these days? Glad to “see” ya.
Can’t complain.
Here’s one of my favorites (friend decided to have a patio cover installed and this is what they found. Pic 2 is the back of the fireplace:shock:)
Nice, no building wrap?
Nope, zero.
Not only kick-out. Gutter would solve the problem.
That is a funny transition on the siding. Is there flashing onder the horizontal board that is transitioned just under the eave ? That could be problematic in the lifespan of the siding.
Also looks like a low spot in the walkway alongside the home in photo # 2. Is it EFIS, is it hard coat stucco ?
Question -
We always recommend kickout flashing if not present.
Twice recently a listing agent got a friendly codes officer to STATE in writing they’re NOT needed AND not required by code.
Both times 4x8 panels of fiberous hardboard siding.
Now I really don’t give a crap AND I know codes state components MUST be installed to MANUFACTURERS guidelines. Anybody got instructions or references (esp code type for sidings and kickouts.
IRC R905.2.8.3 Sidewall flashing. Flashing against a vertical sidewall
shall be by the step-flashing method. The flashing shall be
a minimum of 4 inches (102 mm) high and 4 inches (102 mm)
wide. **At the end of the vertical sidewall the step **
**flashing shall be turned out in a manner that **
**directs water away from the wall and **
onto the roof and/or gutter.
IRC R703.1 General. Exterior walls shall provide the building
with a weather-resistant exterior wall envelope. The exterior
wall envelope shall include flashing as described in Section
R703.8. The exterior wall envelope shall be designed and
constructed in a manner that prevents the accumulation of
water within the wall assembly by providing a water-resistant
barrier behind the exterior veneer as required by Section
R703.2. and a means of draining water that enters the assembly
to the exterior.
IRC R703.8 Flashing. Approved corrosion-resistant flashing shall
be applied shingle-fashion in such a manner to prevent entry of
water into the wall cavity or penetration of water to the building
structural framing components. The flashing shall extend to the
surface of the exterior wall finish. Approved corrosion-resistant
flashings shall be installed at all of the following locations:
IRC Commentary:
The code requires that all points subject to the entry of
moisture be appropriately flashed. Roof and wall intersections
and parapets create significant challenges,
as do exterior wall openings exposed to the weather.
Where wind-driven rain is expected, the concerns are
even greater. Self-adhered flashing is required to comply
with AAMA 711. Although the code identifies a
number of locations where flashing is specifically required,
the entire exterior envelope must be weather
tight to protect the interior from weather. Therefore,
any location on the exterior envelope that provides a
route for the admission of water or moisture into the
**building must be properly protected. **Commentary Figure
R703.8 illustrates examples of flashing.
Larry -
Appreciate this BUT already saw it and still doesn’t use word kickout even if it describes one
James Hardy fiber cement installation instructions. This isn’t hardboard…but
*Figure 9, Kickout Flashing To prevent water from dumping behind the siding and the end of the roof intersection, install a “kickout” of sufficient length and angle to direct the water running down the roof away from the siding.
The earlier versions of the hardy plank installation guides did not require kick outs.
http://www.amvic-pacific.com/Downloads/hardiplankstraightedgeinstall.pdf
I get the same response about the garage door opener button being too low. There is no “code” but the manuf. and CPSC require it.
If I am not mistaken kick-out flashing code is for commercial roofing applications.
There is no kick out code required in residential roofing.
I am also in Canada and code is province and or municipality and you guys state or municipality implemented.
We are not code inspectors.
Kick-out flashing’s on residential roofing surfaces are just recommendations by manufactures to implement or enforce there warranty’s on their material.
That was before water moisture intrusion damage was discovered. ![]()
