no kickout
Just marking my spot to find this again
Roofers didn’t get that memo and then there is the sliding door below this area:shock:
Some of those photos remind me of playing miniature golf, only with waterballs instead of golfballs.
Back in the 2003 cycle this was talked about.
Kick Out Flashings
As someone who is extremely familiar with what may happen to a home as it ages, identification of water penetration issues is paramount during the inspection. Among these, the lack of a kickout flashing is probably the most frequent flashing defect I see, whether new construction or old. Since “code” always seems to come up in conversations about good building practices, take a look at the language related to flashing details from the 2003 IRC:
Read the full article here and at the end especially.
I can’t imagine where they thought the water would go beside inside the wall…:shock:
I just can’t imagine that they gave it one thought.:roll::roll:
I don’t really understand the need for kickout flashing where exterior walls are brick, but with any other siding material, including stucco, it’s obvious; If there’s an avenue for water to enter the wall structure, water should be diverted and the opening should be sealed. And it doesn’t matter whether any building code calls for it or not.
Ken, the moisture is entering through siding, not brick, although it’s getting behind brick installed below the siding. I’m talking about all-brick exterior walls.
Maybe use narrative wording that more closely follows the IRC/etc., wording…:-k You know, spell it out for them…:roll:
But on an all brick or rock wall its deteriorating the brick or stone as well the mortar and thereby getting into the wall cavity.
I can’t picture it, Ken.
Are you thinking that because your assuming a brick wall was built correctly.
