Looks like the drain pan was old an rusty and a repairman
rerouted the drain line …
Does this look like an acceptable repair ? Or she should I request further evaluation by a Licensed AC Contractor…
David
It doesn’t look like a professional repair. did they use tape instead of glue?
No, recommend repair/correction by a qualified HVAC technician and move long.
It looks like tape …Thanks
I will write it up …
Thanks Larry
Replace everything.
Also there is another problem (more important) that cause the pan to get in that condition in the first place.
Broken evaporator pan, Low refrigerant (leak), unit is freezing up from air flow issues …
Check for water damage. Install a drain pan shutoff safety. No open risers in new installation.
