Originally Posted By: pdacey
This is a new subpanel that is tapped off of the original in the house. Note the cable entering in the top right corner. The black and red wires are connected to a 30 amp double pole breaker. The white is connected to a 20 amp breaker and the ground goes to the bus. Why would this be?
The panel was not labeled, I have no idea what these breakers served in the house.
[ Image: http://www.nachi.org/bbsystem/usrimages/I/IMG_5448.JPG ]
Slainte!
Patrick Dacey
swi@satx.rr.com
TREC # 6636
www.southwestinspections.com
Originally Posted By: jpope
Plain and simple Pat, it’s wired improperly. It looks like someone tried to wire two circuits with that configuration. Possibly a 240 and a 120.
The neutrals are also bonded to the grounds at the bus. It also looks like a three wire feed with no GC. FUBAR
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Originally Posted By: bbadger
A total guess here but it looks like they are using that 3 wire cable to feed a 240 volt load on the red and black and using the white and bare to feed a 120 volt load.
Whatever the case this needs to be repaired by an electrician.
Bob Badger
Electrical Construction & Maintenance
Moderator at ECN
Originally Posted By: hgordon
Yikes!
![aiwebs_024.gif](upload://rfqLfpSYWTEcWBA2n8DrT47UcIK.gif)
Nothing new from me. I agree with Jeff (as usual...gotta stop doing that!)
Harvey Gordon
SE Florida NACHI Chapter - President
hgordon@fl.nachi.org
Thanks guys. I knew it looked wrong but I just wanted to make sure there wasn’t some obscure wiring method I have never seen.
Yes and yes. That is also only #12 wire on the 30 amp breakers.
and this is how the panel was fed from the adjacent original sub panel:
[ Image: http://www.nachi.org/bbsystem/usrimages/I/IMG_5446.JPG ]
Oh, and the branch circuits were all aluminum wire. ![icon_rolleyes.gif](upload://iqxt7ABYC2TEBomNkCmZARIrQr6.gif)
Slainte!
Patrick Dacey
swi@satx.rr.com
TREC # 6636
Patrick
So are you saying that the main feed is Alum and they has Copper Double tapped onto it?
...it just gets worse doesnt it?
![eusa_think.gif](upload://lNFeGuTetUAtwNVgUSOuUzgrGGK.gif)
Harvey Gordon
Yes, and yes it does.
I could not find what the second (newer) sub panel was feeding in the house. It was bizarre.
Slainte!
Patrick Dacey
swi@satx.rr.com
TREC # 6636
Originally Posted By: rmoore
Really nasty! Normally I would report that as a “Safety Concern” and “Prompt Repair”, but Jeff has me thinking that I need a new category. Would FUBAR be too unprofessional for a report?
Richard Moore
Rest Assured Inspection Services
Seattle, WA
www.rainspect.com
Jeff Pope
“At JPI, we’ll help you look better”
(661) 212-0738
