QOD for 3/21/04 (Interiors)
Originally Posted By: dbush
Sticking with Gerry’s topic. Thanks to dcarrol for today’s picture
![](upload://5ZGiTP7x77qrrvTYsb6grkwQ1Cf.jpeg)
Dave Bush
MAB Member
"LIFE'S TOUGH, WEAR A HELMET"
Originally Posted By: ladams
Shouldn’t doors between the House and Garage should be Fire Rated?
Originally Posted By: rcloyd
Lind:
The 2003 IRC requires solid core wood 1 3/8 inches in thickness, solid or honeycomb steel doors not less than 1 3/8 inches in thickness or 20 min. fire-rated doors.
Regards,
Russell G. Cloyd
Intra-Spec Home Inspections
& Code Consulting, LLC
859-586-4591
www.intra-spechomeinspections.com
So actually it could be any of the answers if they were 20min doors.
Originally Posted By: jfarsetta
Older homes used hollow core doors with galvanized steel sheathing nailed in place. This was an acceptable standard, and is still accepted for older homes. Where is that answer? It goes to Kevin’s point, exactly
Joe Farsetta
Illigitimi Non Carborundum
"Dont let the bastards grind you down..."
Originally Posted By: jhagarty
Is it acceptable?
Joseph Hagarty
HouseMaster / Main Line, PA
joseph.hagarty@housemaster.com
www.householdinspector.com
Phone: 610-399-9864
Fax : 610-399-9865
HouseMaster. Home inspections. Done right.
In many towns up my way, there is a code violations check performed prior to the transfer of ownership. Based upon the vintage of the home, the AHJ does not require the door or configuration to be changed. So, yes, I would say that to the fire marshall and building inspector it would be considered acceptable.
We're talking about original equipment. Are you stating that it must be changed, Joe; or was this a rhetorical question?
Joe Farsetta
Originally Posted By: ckratzer
IRC and ICC requires 1 3/8 " solid core 20min fire rated along with self closing hinges between garage and living space.
