I found a ring attached to the roof. It looks as though it is attached to a bracket on a roof truss. I expect that it was a part of the installation process, but why was it left behind? Shouldn’t it be removed?
For the roofers safety Harness . Roy Cooke
Best to leave it there and use it for Santa’s reindeer. ![]()
I agree it was for safety tie down. Unfortunately, OSHA Standards for a Life-line hook-up has to be rated for 5000#. I would still hook up to that rather than slide off the roof.
Nice to see that the OSB was manufactured in Easton , Maine. About the few industries left in this Aroostook County other than Paper Mills and those are closing everyday.
Marcel
</IMG></IMG></IMG>
How about a make shift flag pole holder?
That looks like a standard guy wire hookup for an amateur short-wave radio antenna. I have a lot of them around here because there are a lot of short-wave radio guys operating here, especially when Mother and Father Nature come a-callin’ (wildfires, earthquakes, and mudslides). We also had a lot of short-wave radio operators in Texas for hurricanes and tornadoes.
That does seem to make sense, especially, since it appears lower down the roof than near the ridge where I have seen the safety tie downs.
Looks like it is about a foot and a half down from the ridge to me.
Marcel
Yes but the clamp they used I wonder how could they fasten it to the ridge .
Nice and handy to the light bulb for heat never have much ice on it if they leave the light turned on.
Roy Cooke . Royshomeinspection.com
I understand the safety issues here but in my mind if the roofing guys leave them exposed it is just a leak waiting to happen. Tuck them under the sheeting and be done with it.
Larry
Or use the safety bracket that you see below and remove it when done working on the roof.
http://www.osha.gov/pls/oshaweb/owadisp.show_document?p_table=INTERPRETATIONS&p_id=24366#
http://www.gemplers.com/pix/nav/logo.gif
http://www.gemplers.com/pix/nav/space.gif
http://www.gemplers.com/pix/nav/statement3.gif
http://www.gemplers.com/pix/nav/people3.jpg
Catalog Quick OrderOrdering InformationCustomer ServiceView/Track OrdersCheck Out 0 Items In Your Cart
http://www.gemplers.com/pix/nav/leftsearch.gif
/************************************************ Cool DHTML tooltip script- © Dynamic Drive DHTML code library (www.dynamicdrive.com)* This notice MUST stay intact for legal use* Visit Dynamic Drive at http://www.dynamicdrive.com/ for full source code***********************************************/var offsetxpoint=-60 //Customize x offset of tooltipvar offsetypoint=20 //Customize y offset of tooltipvar ie=document.allvar ns6=document.getElementById && !document.allvar enabletip=falseif (ie||ns6)var tipobj=document.all? document.all"dhtmltooltip"] : document.getElementById? document.getElementById(“dhtmltooltip”) : "“function ietruebody(){return (document.compatMode && document.compatMode!=“BackCompat”)? document.documentElement : document.body}function ddrivetip(thetext, thecolor, thewidth){if (ns6||ie){if (typeof thewidth!=“undefined”) tipobj.style.width=thewidth+“px"if (typeof thecolor!=“undefined” && thecolor!=””) tipobj.style.backgroundColor=thecolortipobj.innerHTML=thetextenabletip=truereturn false}}function positiontip(e){if (enabletip){var curX=(ns6)?e.pageX : event.clientX+ietruebody().scrollLeft;var curY=(ns6)?e.pageY : event.clientY+ietruebody().scrollTop;//Find out how close the mouse is to the corner of the windowvar rightedge=ie&&!window.opera? ietruebody().clientWidth-event.clientX-offsetxpoint : window.innerWidth-e.clientX-offsetxpoint-20var bottomedge=ie&&!window.opera? ietruebody().clientHeight-event.clientY-offsetypoint : window.innerHeight-e.clientY-offsetypoint-20var leftedge=(offsetxpoint
Well, I guess I screwed this one up. ha. ha.
Marcel:)
Depending on the size of the antenna, as well as the number of antennas (both of which indicate the seriousness and/or experience of the short-wave radio operator), as well as the location of the antenna (which affects antenna coverage), as well as the siting of the structure (which affects where the guy wires are run), one can find guy wire hooks anywhere on a roof, ground, sides of buildings, etc. Even had one house a few months ago where two neighbors were both serious operators and had used each other’s roof for guy wires to their antenna. One of the neighbor’s was my Client’s prospective house. Of course, I had to point that out to my Client, who wasn’t exactly happy that someone else’s antenna was attached to his roof, which left his roof open to leaks around the guy wire hooks.
Briefly read y’alls notes. Is it a guy wire thinga ma giggie? Never see them leave roofing jacks here. It did look like a very walkable pitch though and probably only a two story at most, so leaving a safety jack seems like a waste (unless it’s a code to leave it) especially since they will only caulk it where it penetrates the roof which may end up leaking.
Odd to see it exposed. Around here they usually put a rubber boot cover over it. Id make sure there isn’t a water penetration point at the roof surface of this one. Just a thought.
Greg
IN CANADA ANYONE WORKING I THE CONSTRUCTION INDUSTRY HAS TO BE CERTIFIED IN ‘FALL PROTECTION’ THIS RING IS COMMON IN RESIDENTIAL,COMMERCIAL,AND INDUSRIAL CONSTRUCTION.IT IS VERY COMMON TO LEAVE THEM IN PLACE.
MARIO
I would love to take issue with that statement but I just don’t have the time to get into it.
Larry
When you leave them, doesn’t anyone complain?
I agree that some of those safety rings or attachments, should be removed when done, and left clean for aesthetics reason. If such roof style would have serviceable equipment of any kind and the roof pitch were to be in the range of 6/12 ,12/12, then I would consider leaving and having the roofer sealing them properly at the ridge and assure that the hook-up meets OSHA requirements for the tie off. The tie off rings or eye bolts should be galvanized or stainless and a minimum of 3/4" diameter to meet the 5000# test.
Marcel
</IMG></IMG>
But if they are, indeed, for the antenna guy wires, they don’t need to meet the 5000# test. They usually get left behind at the SWR houses and no one notices until a home inspector or roofing contractor comes along to find them.
