Says, Stop basement flooding in heavy rain lolll
he’s a former HI in case some don’t know.
Lady caller says LOLL, they bought a house about a yr ago and were told the basement floods…
smdh
Well, they should have looked into this problem before slapping a bid on the house, sheesh
:30 mark… he ‘gets’ that interior drainage system co’s are full of it etc, hurray give him a cookie for that. Some HI’s don’t even get that much! lol
1:22 ish, he says, can correct it on the outside and it won’t be that hard nor expensive to do.
hmmm, okay. lollll
then he gets into his 2 things 1) grading 2) roof drainage
3:40 he says, claims lolll 'Those 2 things will stop this wet basement and i know that for certain!
really, wow that’s pretty interesting now isn’t it. Care to put that in writing and guarantee Tom? No, of course not.
Just like many politicians they just say whatever bs comes to mind, no worries.
Has he ever waterproofed a basement, part of a basement where homeowner leaked and guaranteed it? Is he an expert on this subject? loll shtt
He never once said, you need an honest experienced contractor to come over and determine aka identify, how–where the water is getting in. Then you can fix, repair, waterproof whatever the problem (s) turns out to be.
Never once said, they may have 1 or cracks in 1 or more walls and if so then it’s the cracks that are allowing water in n need to be waterproofed
Never said, if poured walls there could be 1+++ leaky deteriorated rod holes and that is what needs to be determined then repaired correctly
Never said, water could be getting in ABOVE ground, above 1 or more F-walls and then running down the walls behind drywall and if so then that is what needs to be fixed
Never brought up, asked, if she gets any water coming UP through a floor drain or crack in B-floor
Never asked if water was seen ALL around perimeter on these heavy rains and if so, could be a blockage in lateral line aka clean out n a need to get an honest plumber over
Never asked if she has a sump pump… and so on.
Sometimes one needs to run a water test with a hose to FIND the actual problems BEFORE a homeowner spends 1 lousy cent.
Why couldn’t Mr Tom say something like, i would need to come over, be on site, to be able to help you.
We know he’s not going over there!!! I get it, sheesh lolll, am saying SHE needs someone honest with real experience to help find the problem (s), not guess and toss nonsense out on the airwaves.
Doing a water test to make sure… ummm to be “CERTAIN” lol, whether some or all water is getting in through a crack below grade on exterior of basement wall – BEFORE a homeowner spends any dang money
Water can come out chimney chute door from… ready? lol An exterior crack in F-wall etc below ground level AND from any possible openings in chimney above ground, tuckpointing, flashing etc.
So i will rule in or out the first possibility, if it leaks as it did here then they need EXT waterproofing of chimney walls. And some homeowners need BOTH, waterproof exterior of chimney walls and they’ll need to find where water is getting in above grade in chimney and then hire someone exp’d n honest to fix part 2
sorry if i put this in wrong category lollll
