Student Discussion: The 2021 International Residential Code® (IRC®) Exam Study Course
  • What special conditions apply to the installation of a solar energy system?
Installing a solar energy system involves adherence to specific conditions and regulations. Common considerations include compliance with local building codes, obtaining necessary permits, ensuring proper system sizing, and coordinating with utility companies for grid connection. Professional installation and compliance with safety standards are paramount.
Session 1: What is the purpose of the IRC? It brings together all building, plumbing, mechanical, fuel gas, energy and electrical provisions for one-and-two family residences.
Session 2: What is the definition of light framed constuction? Construction whose vertical and horizontal structural elements are primarily formed by a system of repetitive wood or cold-formed steel framing members.
Session 3: What is the minimum required size of the largest habitable room in a dwelling unit? Every dwelling unit shall have not less than one room that shall have not less than 120 square feet of net floor area. strong text
Assignment 1:
When there is a conflict between a general requirement and a specific requirement, which provision shall be applicable.
The specific requirement will supersede a general requirement due to the controlling measures inherent within the specificity of details in said requirement. General requirements are not detailed enough to fulfill specific building practices, building materials, or the intent of the IRC.
In reference to Writing Assignment #14, 2021 IRC Exam Study Course: Shower and tub/shower combination valves required by this section shall be equipped with a means to limit the maximum setting of the valve to 120°F (49°C) , which shall be field adjusted in accordance with the manufacturer’s instructions to provide water at a temperature not to exceed 120ºF. P2708.5
Session 4. What is the minimum size required for a landing? Under what conditions is a landing not required on each side of an exterior door.? Landings shall have the minimum dimension of 36 inches measured in the direction of travel. The exception is balconies less than 60 square feet.
Session 5. How must lots be graded? What is the minimum required slope of the grade away from the foundation. Surface drainage shall be diverted to a storm sewer conveyance or other approved point of collection. The grade shall fall not fewer than 6 inches within the first 10 feet.
Session 6- What is the minimum permitted thickness for concrete slab-on-ground floors? How must the site be prepared? Floors shall be a minimum of 3 1/2 inches thick. Foreign materials shall be removed a 4 inch base course shall be installed where the slab is below grade.
Session 13. Where must gas shutoff valves be located? Where must appliance shutoff valves be installed? Equipment shutoff valves for a fireplace? The shutoff valve shall be located in the same room as the appliance. The shutoff valve shall be within 6 feet of the appliance and shall be installed upstream of the union, connector or quick disconnect device it serves.
Session 7. What is the criteria for the installation of weep screeds in exterior plaster applications? The weep screed shall be placed not less than 4 inches above the earth or 2 inches above the paved areas and shall be of a type that will allow trapped water to drain to the exterior of the building.
Session 8 - How must roof drainage water be discharged? In areas where expansive soils or collapsible soils are known to exist, all dwellings shall have a controlled method of water disposal from roofs, that will collect and discharge roof drainage to the ground surface not less than 5 feet from the foundation walls or to an approved drainage system.
Nicely written.
Session 9 - At what minimum height is a masonry chimney required to terminate. Chimneys shall extend not less than 2 feet higher than any portion of a building within 10 feet but shall not be less than 3 feet above the highest point where the chimney passes through the roof.
Session 10. How high above a floor in a garage is an appliance with an ignition source required to be located? Appliances having an ignition source shall be elevated such that the source of ignition is not less than 18 inches above the floor in garages.
Session 11. What is the maximum permitted length of a clothes dryer exhaust duct? How does the presence of one or more bends affect the allowable length? The maximum length of the exhaust duct shall be 35 feet. A reduction in maximum length of 2.5 feet for each 45 degree bend and 5 feet for each 90 degree bend.
Great post
Great post.
Session 12. What are the general provisions related to hydronic piping systems? How must floor heating systems be tested. Hydronic piping shall conform to table M2101. Approved piping valves, fittings and connections shall be installed in accordance with manufacturer’s instructions. Pipe and fittings shall be rated for use at the operating temperature of the hydronic system. Hydrostatically at a pressure of one and one-half times the maximum system design pressure, but not less than 100 pounds per square inch. The duration of each test shall not be less than 15 minutes.
Very good.
