Ugh... Woke Alert - Primary Bed/Bath?
Never heard the term “paired home.” so I googled it and this is what AI had to say:
A paired home is two homes that share a wall, while a duplex is a single building with two separate living spaces. Paired homes are designed to look like a single larger home, and they offer more privacy than a front-to-front duplex.
They have all kind iof crazy arrangements now where they try to cram more people into smaller spaces. The two that come to mind are the front and back townhomes and the under and over flats and then there is the old side by side duplex like my great grandfather built.
:laughing: I just did the same on Edge. This is what Co-Pilot said:
A paired home is a type of residential property where two single-family homes share one middle wall and sit on one lot. They can also be referred to as semi-detached or duplex homes. Although they may look like one large single-family home, they have two separate entrances leading into two separate home spaces.
It’s similar to using the term park home instead of mobile home. They are both a house on a hitch, regardless of what you want to call them.
So they should be called parked homes then. :smirk::upside_down_face:
Whatever is needed to keep people from believing that they are mobile homes.
Next change will be the Jack & Jill bathroom changing to I identify as Jack or Jill bathroom!
