Does anyone recognize this Westinghouse service panel? Any recall issues to report? It has Bryant and Cutler Hammer breakers in it, an issue to report. I could not open the cover because of the wood trim around it, another issue to report. Often more information can be gleaned on the main breaker, which is hidden by the cover. This is a 1989 house.
My favorite is when they just must use the stud on one side to build shelves and the cover is about 3/4" covered. All kinds of things start going through my mind (Can I get the cover off and back on? How far was the drive if I have to come back? How nice am I feeling today?). I really hate not getting into a panel and will usually give it a try. Of course, there’s really nothing that can be done about the trim job pictured.
Just had a similar panel with painted wood trim preventing removal of the dead front. I just disclaimed it as non-accessible (as with any disclaimed item make sure you photograph it for the report). Can’t damage the home. Panel covers merely painted to the wall are easily removed after scoring the paint line with a utility knife. Most people don’t think when they do these things.
Absolutely! Look up videos of “service panel arc flash”. You won’t remove a restricted service panel cover again. The only way to remove the cover is straight out, never sideways.
Morning, Matt.
Hope this post finds you well and in good spirits today.
Similar setup only with a electric baseboard thermostat from an inspection 2 days ago.
Referred to an electrical contractor for proper dead front clearance.
