Doorbell transformer mounted to a blank plate on a round ceiling or wall box.
I had a door bell button stick the other day, it worked once, then when I was meandering around I smelled something cooking, the transformer.
that puppy SEIZED on ya…usually when I see this it is a faulty button that LOCKS the thing down…probably the NEIGHBOR kids doing the old “Press and Run” deal…
Ok Paul, here is one I have never seen before. In a Federal Pioneer breaker panel the electrician who wired it put a receptacle into the bottom right hand side of the case. I have not seen this done before and it left me scratching my head a little. I am aware, the code says the panel should have a receptacle mounted directly adjacent to it for service purposes but this just did not seem right.
What say the gurus?
Larry
The main electrical panel box, cannot be altered in such a way as to cut in a electrical receptacle. There should be a seperate device box for receptacle at panel.
Some panels actually have a receptical shaped knockouts near the bottom. I’ll grab a picture for this thread the next time I see one.
I have seen newer panels with a plug outlet installed right in the panel. Its not unusual.
Thanks Guys
It was the first for me and I wondered.
Larry
Larry,
Hey…sorry getting back to you as I have been swamped with blueprints…always a good thing for a EC.
Normally electrical panels do not allow receptacles within them, now I have installed alot of panels and I have not seen any with a pre-installed receptacle but I am sure they exist…just I have not run into any.
You can’t simply add a receptacle to a panel enclosure…but if the panel is designed to have one in it ( much like we see on structured wiring panels ) then it is fine.
The ones to call out are the panels you KNOW do not have a need for an receptacle and an aftermarket FIX has added one…that is when you should call it out atleast to be reviewed.
Joe T our "Senior" electrical trainer may have more on this...thehehe..sorry JOE..I could not resist....
OK…back to the pricing I go…any electricians out their need a JOB…
Some cabinets are designed for a receptacle. I have a picture of a 50 amp receptacle installed in the cover of a 200 amp panel, (illegal) and the 50 foot cord near it that was used to supply the hot table in the hotel parking lot when car shows were there is a classic!
“Senior” can be considered in two ways, the “Old Man” that I am, and one who started at the age of 13 in 1953.
Here’s the picture of the two guys who were on their 4th or 5th LIIT in OHIO.
Gee Paul that guy on the right sure looks like a senior to me, he even has a senior citizen card. The guy on the right was the instructor dude. :mrgreen:
Hey brother…just teasing ya…Hell you look 100% better than me YOUNG man…heck I am only 37 and you got me beat…
I actually think the version " started at 13 is best…" because I like you fella…
lol…I just could not resist…you know me by now…tehhehe:)
OMG…I look awful in that PIC…I look like I am a balding eagle…GESSHHH…man…burn that puppy Joe…lol
Atleast no one posted a picture of my GUT in the gallary…
Actually…I take that back…I did do some installs with receptacles in the actual panel…when I made up a bunch of temp poles for a sub-division.
However these panels were " designed " for this installation and had actual receptacle plug openings in the enclosure and obviously it was listed and labeled for the application.
Just taking a normal panel and slapping a receptacle in it…would not JIVE…man I am HIP tonight
Boy O boy you guys look scary!!
The type of guys that could scare a few home inspectors… into learning a few things here and there…
Paul was discussing the position of the grounding terminal here on a receptacle, and was using an interesting method to find any heat.
He really is a funny guy and has a lot of jokes to tell. He is almost 6 feet tall so don’t let the picture here fool you!
:mrgreen:
Excuse me, do you find something wrong with… “looking like a bald eagle”??
lol…OMG…man that cracks me up…no it looks GREAT on you fella…you have the LOOK…I simply LOOK bad…
Man…I stepped in THAT one…
lol…well it was AWESOME having you in the class…HEY…don’t tell them how tall I am…I like them thinking I am a squatty, fat fellow…thats my method…lol…the old Fat, Squaty, Balding Virginian…now you have ended my stand up routine…![]()
Wow Paul,
Nice Tie and shirt… Very professional… Do you wear that during an inspection?
Joe , Paul,
So guys are you keeping up with all the “electrical new stories” around the country? Probably too busy…
Major power problems in St. Louis and L.A … Record power consumption with all this heat and A/C use… Talk about poor infrastructure, the city POCO was hauled to court one year not to long ago for numerous “equipment” failures…
The number of splices on the power lines must have been at an all time high…
What do you guys (super sparkies) see as a key in reducing power
consumption? If any? Education , Equipment for the consumer.
Wind mill in the yard and solar panel on the roof…:shock:
Just a note:
It was mentioned earlier in a post that the panel requires a receptacle near it. That may be a local code, but it is not in the NEC. Panels do not require any receptacles near them, some install the receptacle with a nipple to the panel and the box supporting the receptacle in a basement, as the unfinished basement requires a receptacle, but the location is only used for convenience.
