Its called follow the sop we are not required to walk a roof .
(F) **.Inspectors are NOT required to: …**1.Preformany procedure or operationthat will,in the openion of the inspector or ,likely to be dangerous to the inspector or other persons or damage the property or its system or componets.
The Construction Safety act also say we all need to have taken the training and exam before we can climb a roof .
It also says we must have a proper harness safely tide of before climbing a roof.
Disclaim no access can not inspect the roof and give the reason, recommend further evaluation by qualified personal.
Covered two ways at least for not doing the roof… Cookie
Say something like that down here where there are quite a few low slope and flat roofs …you’ll definitely lose points on personal reputation. People don’t like to pay for another inspection after paying the HI!!!
With the right ladder, at least you can get to the roof edge from a couple/few locations to gauge the general roof condition…no need to walk the roof…although I do it most times on low slope/flat roofs.
I, too, have the LG 26’ and am looking to “downsize”. It is just too cumbersome and heavy for the interior portion of the inspection. In addition, it is awkward, if almost impossible, to extend the ladder to the maximum height and raise it. I purchased it to use on higher elevations, but am now finding it just too big and difficult to raise. I have raised ladders for years in the fire service, on ladder truck for most of it, so I know difficult or awkward when I see it.
Good solid ladder, great stability, well built. Just too big. I am going to sell it and purchase a smaller LG.
Hi Guys,
I just purchased the extend and climb 15.5 that Barry mentioned.
it is well built, but I gotta say, I weight 165 and it has quite the bow
to it when fully extended. If I was 200 (god forbid!!) I would not climb it.
for 279$ I am not thrilled, and I prefer my aluminum extention 26’
I just bought the same ladder and so far like it. At 200 lbs, I don’t seem to bow it excessively but, with all the Chinese quality problems in the news lately, I was not impressed to see the “Made in China” sticker.
Carla,
Maybe the bow is because of the ladder in a position in which it is not at the proper 70 degree climbing angle?! Try that degree and see if it still bows. It shouldn’t bow that much if used as designed. (Easy to get the 70 degrees - Put ladder up to desired height and angle, stand on first rung or ground (level) and reach all the way out with arms palms down. If you reach the rung in front of your hands without any movement of the arms, it set at the proper angle to climb.) If the rung does not meet your hands, adjust the angle of the ladder to meet the criteria. Good luck and be safe!
Dennis,
I recently had to sit through a course that included the usual bit on ladder safety. I seem to recall that the 70 degree angle that you mention should be about 55 degrees, to maintain the 1 to 4 ratio. Although, I must admit that often times I set my extend/climb to a steeper than safe angle, to really reduce that “bow” that comes with the 15 pounds I’ve put on.
John,
Thanks for the info, this may be new info on the degrees. Fire service still states 70 degrees with five rungs above the roof line. We certainly don’t need to have 5 but at least three to grab the ladder to get on. You hit the correct ratio with the 1 to 4 i.e. for every four feet move the heel of the ladder away one foot: twelve foot roof line should have the heel of the ladder three feet away from a straight line down form the roof line, allows for a soffitt. That is what should really be remembered. Thanks again for the info. Safe laddering!
Carla,
I just bought this baby aboiut two weeks ago of PE. I weigh 180 and have no problems. I love it for the exterior (three times today) and use the telesteps 12.5 for interiors. Great ladders. Dennis and John have great points and use these ideas as a guide to raise your ladder to. As for me, I will find a guide to raise a glass to (or my third) :mrgreen:
Oh and yes… keep your fingers back!
My choice was the Gorilla brand (13’). B.J’s, Costco, H.D.,Lowes had them at the time I was looking.
I chose 13’, because I will inspect from the gutter line of most homes, but don’t walk roofs, as a rule.
They come in handy inside, for access to attic spaces that don’t have pulldown ladders or fixed stairs, etc.
At 285lbs., I’ve felt comfortable and safe.
For a number of reasons, after reviewing all the recommendations, Consumer Reports evaluations, etc. I have decided to start with the Telesteps 1600W found at toolup.com for $229 + 6.95 shipping (most other sources were $270-300). I like the light weight and compact size. Only tried it a couple of times so far, but seems to be a good one. Thanks for all the input - I’m amazed at how many responses this thread generated.
I bought a folding 17’ Werner ladder from Costco last year for $99. Great ladder and easy to use when having to try and get into small closets to access attic hatches. I have not seen it recently in Costco, but they may get some more in their inventory.
