Just asking Juan. I would like you to be included here. What do you see?
Its not a wood framed wall
It does look like there is a 2x8 placed on the far exterior edge of that empty space. Are you saying Juan that what looks like wood at the exterior edge of the empty space is actually the backside of those reddish decorative mantels over the windows?
The window framing on the left blocks to much information. Assessment is default at best with these photos.
hard to insure a guilty hypotheses IMO.
It is a mess and I would be referring this to a GC from what I see.
The left top portion of the suspect 6"x6" header beam is notched. You can not see the bearing.
The 6"x6" is now a 4"x4" with poor bearing on the left and suspect beam header deflection.
The flooring above will or is dropped.
Ether/or it can be ungraded and not a large expense to stiffen the window openings.
SUSPECT: The wall openings do not have proper header beam for the spanned opening for the windows.
RECOMMEND:A licensed RBQ contractor or GC evaluate and repair or upgrade the wall opening for the right material to use to span the opening for the windows.
LIMITATION: window frames blocked much out the suspect defects in question.
I would say about $1000 to $1300 per opening. That is to span and install what is needed.
A contingency fund of up to 50% of the contract should be set aside encase unseen issues arises.
NOTE; A lintel Bob would be for a veneer. This is a wall.
What a piece of crap!
Actually I corrected myself but see lintels with CMU type and split blocks all the time.
Just not in this case .
Not sure this would do any good as the whole wall needs insulated but this is what I would recommend here.
http://expressheader.com/images/logo_small.gif
Insulate & Install with Ease
Simply a Better Window & Door Header...Since 2003!
Insulation value of R16 helps achieve new energy codes.
One-piece express insulation allows for faster construction.
LVL material tested for roof and floor loads, available in 3-1/2" and 5-1/2" widths.
Full engineering, including software/charts.
Coated for construction site weather protection.
Include the ExpressHeader in your next project and get the right size every time.
*ExpressHeader* Facts SJS Components *ExpressHeader* was developed to be a cost reducing, time saving, energy efficient window and door header for 3-1/2" and 5-1/2" construction. The *ExpressHeader* is a structural product manufactured with 1-1/4" APA approved LVL. Its foam core is an Expanded Polystyrene that helps eliminate unnecessary wood fiber. This allows you to utilize only what is needed structurally. Builder & Customer Benefits Panelizers and Production Builders around the United States are realizing the benefits of the *ExpressHeader*. Since it is a one-piece "express" install, the days of building window and door headers are over. Available in lengths up to 16', cutting is easy and effortless. Two different nailing patterns also makes nailing a breeze. Not only does the *ExpressHeader* save you time, it offers a strong selling point for you to your customers. Many window and door headers are not insulated. However, the *ExpressHeader* offers an R Value of 7.75 on the 3-1/2" and 16 on the 5-1/2". This will help your customer reduce their energy use since the whole wall will now be insulated.
http://expressheader.com/images/EHLITE_logo.gif
Introducing the EH LITE!
Now available from SJS Components, the *EH *LITE offers many of the same benefits of the ExpressHeader at a reduced price point. Constructed of 1-1/4" LVL, Expanded Polystyrene and 7/16 OSB, the EH LITE is stocked in both 3-1/2" and 5-1/2" widths x 11-1/4" depth. The 3-1/2" width includes 1-3/4" Expanded Polystyrene and the 5-1/2" width is constructed of 3-3/4" Expanded Polystyrene.
http://expressheader.com/images/EHLITE_loadtables.gif
Installation Notes
The *EH* LITE can be installed with the LVL side facing in or out. A 2-x must be nailed to the top to control rotation and a proper bearing installed at each end.
[Download the flyer](http://expressheader.com/images/EHLitebro_web.pdf) for additional information and installation details.
http://expressheader.com/images/EHLITE_wrong.jpg
***Example of improper installation!
When dropping header down from top plate a 2-x must be installed on top of header in which to nail studs.
Proper bearing must be installed at each end.
For More Information
Available throughout the U.S. and Canada. For more information regarding the *ExpressHeader *or *EH *LITE*,* contact Scott Brown at (260) 578-0192 or e-mail info@sjscomponents.com.
Located near Warsaw, Indiana, SJS Components was founded by the developers behind the *ExpressHeader*. Additional products by SJS Components include [Timber Trusses](http://www.sjscomponents.com/trusses). For more information regarding SJS Components and their products contact Scott Brown at (260) 578-0192 or e-mail info@sjscomponents.com.
http://expressheader.com/images/bottombar.gif
© 2012 SJS Components, All Rights Reserved.
I know this has been mentioned before but you can see it is recognized by EERE.
http://apps1.eere.energy.gov/buildings/publications/pdfs/building_america/26449.pdf
What say you Juan? I’m still curious.
And so am I.
That’s about how I see it as well.
If that’s 8-8 CMU … that’s gotta be more than siding… dunno.
I’m really not sure what you guys are seeing. Not your fault though. The pics are horrible. You can see the bottom of the top plate though. There’s nothing under it.
There is a piece of wood bearing on CMU but I think it’s function is to hold the window in place.
Yes the wood you see on the inside is from the wood on the outside.
I already wrote the report. The parge coating had cracks around all the windows. I deferred it out.
That would be the header, or as Marcel called it “make shift header”.
He pointed at blank space…
It’s not taking any weight from above and distributing it so its not really heading anything.
The peice of wood bearing on the CMU is just there the give the top of the window something to attach too.
http://www.nachi.org/forum/attachments/f23/61525d1358039275-best-inspector-img_2084.jpg
“Header supporting top plate” is the piece of wood bearing on CMU’s.
