Could some give me the age of a Winchester furnace (Hamilton Home Products)? Model FG9B08012UP11C Serial WKLM065197 this is the best I could get as it was faded. I hope this is enough info.
Thanks in advance
Randy
Hi to all,
Randy, that model number is from a Luxaire Gas Furnace built in either 1999 or 2000.
Regards
Gerry
Thanks Gerry,
Can I try one more that had no name AC unit Model # BRCQ0361BD. Serial # 021211658.
Thanks again,
Randy
Must not be my best HVAC week!
Randy, you’re a sad case :mrgreen: Buy Prestons
That is a Coleman unit between 1997 and 2001
Regards
Gerry
I get 2002 for that one.
I get December 2002 for that one.
Hi Russel,
I am sure that you are correct with those dates, my version of Prestons in 4th edition 2001 so Appliances built after 2000 are not covered (I have just seen that they now have a new edition out that covers up to 2005)
Regards
Gerry
If the furnace is a Luxaire then is was manufactured by York-Borg Wagner and the 3rd letter is the year so it it is either 1981 or 2002. The A/C is most likely 2002 also. Which would make sense that both units were installed at the same time.
