Hip, Flat, or Other?
Ran into an interesting one today. Main structure is Hip in shape, left side and front have a small flat area. Flat area is connected to the face of the block structure (see pics 3&5) with framed exterior walls (it was a carport/front porch which has been framed in). So basically the whole exterior wood framed flat area could be blown down and not compromise the interior block/hip area.
Flat, not a carport or patio. Enclosed living space.
What is the roof shape(s)? (**Porches or carports that are attached only to the fascia or wall **of the host structure and not structurally connected to the main roof system are not considered in the roof geometry determination.)
C. Flat Roof Flat roof shape greater than 100 square feet or 10% of the entire roof, whichever is greater.
From thos pictures is that " SMALL enclosed living space". There is no insulation and most likely no heating or AC…looks like enclosed space…but not LIVING space.
You could likely tell from the inside. From what I see when I encounter areas like that they are usually unpermitted additions or enclosed areas turned into a living space.
