Wrrrrrrrrrrrrrrrrrrrrrrrrrrrong!!! This incompetent crap has got to STOP, you people are WRONG man, g dang!@!@!#$$#! ](,)](,)](,)](,)](*,)
short video http://www.youtube.com/watch?v=W-VgKiB5pAk
:45 “You relieve the hydrostatic pressure behind the wall by drilling all these little weep holes”
All due to ‘Peg’ but geeeeeeezus Christmas man, you do not know what your talking about.
Look g dammmmmmmmit, there is water INSIDE the hollow-blocks and it is getting inside those blocks from openings/cracks etc on the…
OUTSIDE. That’s where the problems are, that’s where the SOLUTION is,
perrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrriod.
You should take the $1,000 or whatever the cost for that garbage is and use it to pay for exterior waterproofing in the area(s) needed!
HIGH— (some certainly are!) —drostatic pressure is NOT, could never be, relieved by drilling a shttload of HOLES in block walls!@!@#$$%%%$##@!!
Some need holes drilled in their heads!!@@!!!
ALL anyone is doing, by drilling these stttoooopppppiiiidddd holes is, letting water that is getting into the blocks, out. Water will CONTINUE to get INTO the SAME blocks (and weaken mortar joints etc), because you FOOLZ did not, have not, fixed/waterproofed the exterior cracks etc! You have NOT relieved pressure against—the–wall!!!
Get your azz’z on here and fully explain to MY dumb azz exactly how drilling weep holes in block walls will relieve pressure/weight on the outside of the g dang basement wall!!@##$$^^&_&^$$$^&%&%(*(&^%%%$$%$^^!!!
Here she is again…another short video
:25 “When it rains, water leakage at water line… at–near corner”
That’s because there are exterior cracks in the STOOOPID basement wall(s) and an opening/crevice/gap on the outside of wall where that STOOPID line goes through the STOOPID wall!!! Hello!
STOOPID. looooooooooooooooooooooooooooooooooooooooooooool
Spending money, time, on crap that does NOT stop the water from where the HLLLLLLLLLLLLL it is coming in.
And your not going to stop–prevent mold, efflorescence either with any interior basement system, your out of your minds. Drrrrrrream on. Hope, pray for a stooooopid miracle, un—be----lievable shtt many people do/try and WASTE their money on.
Then some of these same people will sell their house and actually say they, tell buyers, the basement, ‘has been waterproofed’/ BULLLSHT, no it hasn’t.
And here, lolollll is a home inspector in OHIO-----land who posts an article written by a turd who actually recommends the CRAP the lady in videos bought #-o#-o#-o
http://activerain.trulia.com/blogsview/90200/drying-out-a-wet-basement--by--john-d--wagner ](,)](,)](*,)
WHY go and post some bulllshtt on a subject your NOT an expert on, your misleading/screw’g over homeowners/sellers/bueyrs… yes U are!
These same kinds of TURDZ need to come up with a gutter system for leaky ROOFS.
Sure, why the fk not.
INSTEAD of going outside and up on duh roof and locating/identifying and then fixing the actual problem where the water is getting in, stay inside and go up in your stooopid ATTIC and DRILL some holes through the roof to the outside and install a gutter system to channel the incoming water to your toilet and then say/claim, you relieved hydrostatic pressure against your roof!!! Idiotzzzzzzzzzzzzz
