AFCI's
Originally Posted By: jmcginnis
Mike…
I gotta go with Jerry on this one… the article states “branch circuits that supply outlets in dwelling unit bedrooms” must have AFCI protection. If the outlet is for example a light on a deck outside the bedroom and the switch is located inside the bedroom then AFCI protection is not required since the outlet is not located in the bedroom. However, 9 times out of 10 the electrician will parallel off of the bedroom circuit to supply that one light and it will end up protected as a matter of wiring convenience. Eventually, when all circuits in a dwelling unit are required to have AFCI protection the question will be moot. IMHO
Using Joe’s statement
"A device is a unit of an electrical system that is intended to carry but not utilize electric energy.
Then a recpt. would not have to be AFCI protected.???
Mike P.
Mike …
A receptacle is also a device because it doesn’t use any power but the difference is that a receptacle is also an “outlet” because it is a “point” on an electrical system where electricity can be taken to utilize equipment. A switch is a device but it is not a “point” on the system where electricity can be taken to utilize equipment, therefore a switch is not an outlet.
Jack
You are correct.
My point is that both switches and recpts. are "in" outlets. This means that all switches, "outlets", lights and smokes on 15 or 20 amp circuits, in a bedroom, must be on an AFCI circuit.
Mike P.
Originally Posted By: Ryan Jackson
Mike: Next time you have a few minutes, check out this thread:
http://www.mikeholt.com/codeforum/ultimatebb.php?ubb=get_topic;f=11;t=004398
Ryan Jackson, Salt Lake City
If I am not clear read the definition of a receptacle in article 100.
".... installed at the outlet...."
Mike P.
![](upload://xAVDvhVdBrIz3Cyl2zT41iy4Vuq.gif)![](upload://xAVDvhVdBrIz3Cyl2zT41iy4Vuq.gif)![](upload://xAVDvhVdBrIz3Cyl2zT41iy4Vuq.gif)![](upload://xAVDvhVdBrIz3Cyl2zT41iy4Vuq.gif)![](upload://xAVDvhVdBrIz3Cyl2zT41iy4Vuq.gif)
Or you could just grind sand into your eyes now and save yourself 2 hours of reading.
Either way the result will be the same your eyes will hurt and you will wish you did not do it. ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif)
Bob
Now that the sand is out of my eyes, and no I did not read the thread, how do you enforce this?
In the central Ohio area if "it" is in a bedroom you 'will' have it AFCI protected.
Mike P.
Originally Posted By: jpeck
Mike P.
No Mike.
ALL bedroom OUTLETS are required to be on AFCI protected circuits, not switches.
Switches are not "outlets".
Outlet. A point on the wiring system at which current is taken to supply utilization equipment.
Switch, General-Use. A switch intended for use in general distribution and branch circuits. It is rated in amperes, and it is capable of interrupting its rated current at its rated voltage.
Switch, General-Use Snap. A form of general-use switch constructed so that it can be installed in device boxes or on box covers, or otherwise used in conjunction with wiring systems recognized by this Code.
Notice that "Outlets" are "A point on the wiring system at which current is taken to supply ... "
You can have switched outlets and non-switched outlets, but all the switch is doing is controlling the "power on" and "power off" at the outlet.
Jerry Peck
South Florida
Again.
Switches, receptacles, and smokes are at outlets.
Explain the difference between:
Outlet
Receptacle
Receptacle outlet
Mike P.
Please read the following:
http://www.mikeholt.com/codeforum/ultimatebb.php?ubb=get_topic;f=1;t=000096#000014
http://www.mikeholt.com/onlinetraining/page_images/1014150850_2.gif
Mike P.
Mike Parks wrote:
Again.
Outlet
Receptacle
Receptacle outlet
Mike P.
Again (as you say) read what you hath wrote.
SWITCHES are not OUTLETS.
For some reason, convenience or whatever, you INCLUDED switches in the top list,
"Switches, receptacles, and smokes are at outlets."
BUT DID NOT include them in the bottom list.
"Explain the difference between:
Outlet
Receptacle
Receptacle outlet"
Jerry Peck
South Florida
Mike P.
Mike,
I will try to remember to ask Mike about that when I am there in 3 weeks helping him make his new video on the 2005 NEC changes. There are 4 or 5 of us who are going to be helping with his new video.
Jerry Peck
South Florida
Jerry
"BUT DID NOT include them in the bottom list."
Because I have never heard of a switch called an outlet.
And note how 'Mike' identifies all the 'outlets' in the above http://www.mikeholt.com/onlinetraining/page_images/1014150850_2.gif
Mike P.
Mike Parks wrote:
Jerry
Mike P.
Huh?
Your whole basis for stitches requiring AFCI protection is that they are outlets. now you are saying they are not? Am I confused?
Jerry Peck
South Florida
Jerry
What I am saying is: the 'box' is the outlet not the device (switch, recpt., smoke, etc.).
Examples:
Lighting outlet. An outlet intended for the direct connection of a lampholder, a luminaire (lighting fixture), or a pendant cord terminating in a lampholder.
Receptacle outlet. An outlet where one or more receptacles are installed.
Remember the change from receptacles (1999) to outlets (2002) for AFCI's?
Mike P.
Mike the box for a switch is not an outlet.
You might call a switch a point on the wiring system that supplies branch circuit conductors, but as there is often not a neutral at a switch it is hard to say it supplies anything.
IMO a switch is simply another point on the wiring system, it is no more an outlet than a junction box, cable or conduit.
Bob Badger
Electrical Construction & Maintenance
Moderator at ECN
All have "boxes", but the "box" is not the outlet, the "end of" or "tap off" the circuit as a point of use is the "outlet".
Jerry Peck
South Florida
Originally Posted By: jfarsetta
, and not as an endpoint. It exists BEFORE the outlet.
Joe Farsetta
Illigitimi Non Carborundum
"Dont let the bastards grind you down..."
