How would you word this? The tread does not extend past the riser. Cove moulding is in front of the tread.
Potential trip-hazard.
I don’t watch my feet when I ascend a staircase. When I raise and place my foot, I expect the tread to be there!!
Descending is just as bad. I have big feet… size 13… (wink-wink)… and I use every inch of that tread!!
Yup. Beautiful work. Just all wrong.
Not beautiful work, just all wrong.
I found that same image. Yes, 11" would be pushing it.
How often do you find a homes with a poured concrete front stoop with 11 inches and/or a nosing?
Virtually NEVER!
Just sayin’.
How often do you see poured concrete steps with tread nosing’s?
That’s a pretty strange molding to use for the nose of a tread!
There you go again. Posting what others before you have already posted.
Do you ever have an original thought?!!
The joke is, I build concrete steps. When I started you moaned, another builder." You openly laughed at your first 300 hundred inspections.
Lol. Everyone knows you Jonas. Grow up.
Yupper. If the treads were set correctly it would fit nicely under the nose against the riser.
What the hell you talkin’ about??
You get your meds mixed up with your drugs again??
What a … WAFI !!!
Don’t make stuff up.
Sugar on a pile of poo. Carpenter trying to make-up where they f**ked up.
Nice pic, but remember that we are talking residential and not commercial.
Commercial is a whole 'nuther animal.
R311.7.5.3 Nosings. Nosings at treads, landings and
floors of stairways shall have a radius of curvature at
the nosing not greater than 9/16 inch (14 mm) or a bevel
not greater than 1/2 inch (12.7 mm). A nosing projection
not less than 3/4 inch (19 mm) and not more than 11/4
inches (32 mm) shall be provided on stairways. The
greatest nosing projection shall not exceed the smallest
nosing projection by more than 3/8 inch (9.5 mm) within
a stairway.
Exception: A nosing projection is not required where
the tread depth is not less than 11 inches (279 mm).
