Never saw this one before, and I can’t find any info about it. Are gas meters allowed in bedrooms?
You got to be kidding.
Those people crazy or what? Gas Meters have vents on them, how did it smell?
Why not?
Meters are not supposed to leak.
If it was a gas using appliance that would be different however if it was leaking it would effect the entire home not just the bedroom.
Here is Peoples gas code though you may wish to check local…
Meter Installation Requirements
Peoples Energy recommends that meters supplied from medium
pressure service pipes be installed outside of the building.
For medium-pressure areas in Chicago, service regulators shall
be installed. Peoples Energy’s practice is to install both the
regulators and meters outside of the structure. An outside
installation makes it easier for Peoples Energy to maintain meters
and regulators while freeing up interior space for customer use.
Gas meters shall be located:
It is being discussed at: http://www.inspectionnews.net/home_inspection/plumbing-system-home-inspection-commercial-inspection/19500-indoor-gas-meter-childs-bedroom.html
Marcel - that discussion is dealing more with the fact that the bedroom itself is illegal. No smell from the gas meter, but the laundry hamper was ripe LOL!!!
Bob - I couldn’t find a reason why it shouldn’t be there, but it still doesn’t seem right.
It should at least be vented to the exterior.
The local gas provider likely has specific requirements for meters located in doors.
Doesn’t this say it all?
Gas meters will not be installed in these instances:
Gas regulators can leak gas when there are spikes in pressure.
I see meters in homes all the time and mine is in the home also.
They read remotely.
Check local codes for more.
Marcel the last part about owner or tenant I take to mean because of access.
I would write them up if seen inside.
Fairly common to see them inside in this area, just not in a bedroom.
Not up here.
Never stopped to think about some meters not having the regulator at hand on top of it.
I guess it is legal as long as the regulator is remote.
§ 192.353 Customer meters and regulators: Location.
(a) Each meter and service regulator, whether inside or outside a building, must be installed in a readily accessible location and be protected from corrosion and other damage, including, if installed outside a building, vehicular damage that may be anticipated. However, the upstream regulator in a series may be buried.
(b) Each service regulator installed within a building must be located as near as practical to the point of service line entrance.
© Each meter installed within a building must be located in a ventilated place and not less than 3 feet (914 millimeters) from any source of ignition or any source of heat which might damage the meter.
(d) Where feasible, the upstream regulator in a series must be located outside the building, unless it is located in a separate metering or regulating building.
4.3.2.1 An inside meter set assembly must be located as near as practical to the point where the
service line enters the building.
(A) The meter set assembly must not be installed in unventilated or confined space; it must
always be readily accessible.
Most common I see in many homes (50’s/60"s ) is walled off with hatch (similar to picture) with glass bock and facing the gangway for the meter reader.
There are only 3 cities here in Maine Bob with underground natural gas.
Most of them are outside. And the others are LPG and those are outside.
I would feel safer with the outside ones personally.
Marcel if we have gas appliances we already have gas an gas lines all through the home and a meter is not a storage tank so maybe your concern is more psychological.
It is ever develops a leak the chances are no worse than if one sprung up at a union near your furnace for instance though the meter has no pilot lights.
Carbon monoxide is a bigger concern and risk I bet.(make sense)?
Did I ever tell you I hate Gas and propane in a house. :mrgreen:
It’s a heck of a lot cheaper than fuel oil per BTU.
Preference
Assuming you can have either people may like the" instant on" of a burner vs the wait of electric coils, though electric does have options such as induction cooktops Induction cooking uses an alternating magnetic field to make your cookware turn hot through the friction created when the metal cookware swithes fields rapidly.
Think of how you can bend a coat hanger back and forth rapidly and it gets hot at the end point.
What this also means is that the cooktop stays cool to the touch.
Seems this is Similar to a microwave in one sense.Correct me if I am wrong and if you need large scientic words to explain it does not count…lol
With a range you need to pull it out and clean it of what ever gets stuck between it and the cabinets plus the oven size is always a standard 36 inch ,same as the cooktop.
However with a separate oven it is no longer below the micro or rangehood .
http://activerain.com/blogsview/3276787/cooking-appliances-what-kind-to-buy-how-to-decide
